 GenevaCustoms-custom mud mower
mudman604
GenevaCustoms
7 posters
Go to page : Previous  1, 2
GenevaCustoms
GenevaCustoms-custom mud mower - Page 2 Empty
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 4:53 am
mudman604 wrote:
i agree about nothing going to happen, but the ideas of the 2nd set is that your using the same hardened steel that pulls you around anyway. with the fozzy,the theory is it could push out the weld or crush it or even try to walk over it (i dont see that, if it did, the bull gear would be f up by then) also, that this gona fly with that what 3 inch pulley? maybe 2.5?
the picture with the small pulley was reds transmission
mudman604
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 6:17 am
Year, m y bad, you still need 4th gear? How many teeth are on it? Do you need the pair?
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 6:20 am
I think it's third now not 4th lol but either way it's 35 teeth and no it's just that single one
mudman604
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 6:28 am
Darrn, I thought the 700 an 820 had the same gear sets. I was going to give ya my gear from my 700, I'll need to check my gear bucket though. Prob don't because the gear bucket only has MST parts.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 6:33 am
I found a 35 tooth gear from a 209 I didn't know if they swapped out Becuase 820 is bigger, are the gears same size?
mudman604
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 7:30 am
Idk I can switch MST with 700.......
mudman604
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 7:31 am
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 7:33 am
hmmmm I will will either file that gear and make it work or put a spacer in it.
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 3:07 pm
Pretty sure the ID bore/splines would be bigger in a 820 gear set. Errythang is bigger.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 5th 2015, 3:27 pm
that's what I have been thinking but I thought I heard somewhere that they could swap, but I'm not gonna be the one to spend money on gear and test it lol
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 6th 2015, 8:50 am
I'm ordering the powder coated 4on4 hubs from bmikart a soon changed my mind. the flange on the galvanized hubs weren't as thick, and I want beef these ones are 5/16 inch thick and 3 1/2 inch of solid key way to hold the torque. Other one was only 3inch so I feel these are a little more beefy
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 10th 2015, 6:19 pm
Well got the chain a couple days ago and just got to put it back together, reverse works great now lol. Still going to clean up the outside of cases before I start making transmission mounts
GenevaCustoms-custom mud mower - Page 2 352F6D68-CB37-4350-97B6-2DE947CE2671_zpsfmr4b9bm GenevaCustoms-custom mud mower - Page 2 85B31406-8C20-489B-A444-94BA8DA2A03F_zpsougqi2vs
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 10th 2015, 8:46 pm
You should totally give me your half shafts and trade with mine so i have the long version! lol
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 6:17 am
what you mean half shafts? The axle shafts? I feel like u have better luck finding another 820 then me hahah
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 6:58 am
Yea the axle shafts, hard to come across long axle shafts because most 820s come out if Murray's that I know of lol
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 7:22 am
so mine are long? I didn't measure them and do you think I could fit a brake rotor on one side? That's what I want to do..
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 8:49 am
You have them spacers on the ends of the axles, I don't, check my axles. I think mine is 28" so yours is 30" and yea you can fit one, I can I'm sure. If you got time fiddle thru my threads pages and I got a snowmobile disk and caliper for mine. I'm gunna bore the hub out to 1" and weld it to my john deere hubs. You'll see sooner or later
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 8:58 am
alright I will probably get a 6in or 5in from somewhere I have hydraulic caliper and master cylinder and will have to make linkage for it but will only be able to lock one wheel up Untill I lock it so I might run stock brakes till I lock it.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 2:23 pm
Should be getting the rear tranny mounts mocked up and tranny hung on the frame tonoght without welding. I'm just going to probably mock up the rear mounts and not the front tranny mounts tonoght. One step at a time they are being extended about 4inches
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 3:03 pm
Yea, when you put the brake on the axle you gotta lock it or it can get really uncontrollable. You should defiantly lock the axle if you plan on doing all this work, and run the brake on the axle sooner or later, but if youre running stock brakes and need stock brake parts i got some.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 3:31 pm
yea I'm deffinatley going to lock it but for now I wanted to put the axle back together so I could get everything else sorted out and then after if I have saved up some money or have acces to bigger welder i will def lock it. I'm gonna lock it sometime I just don't know when lol and it came with the parts and I think both pads I'll check
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 11th 2015, 7:23 pm
Got the tray mounts extended and started welding but didn't finish, still have to make a cross brace and beef up mounts and extend front mounts, this was just to get it sitting were it needed to be only a 4 inch lift, looks taller then it is, Will fit 24-25in tires nice and snug I measured lol pics GenevaCustoms-custom mud mower - Page 2 78DFFE1D-79AA-4934-BB76-BD1353B8FF88_zpsecgeg3ol GenevaCustoms-custom mud mower - Page 2 2DA17E98-ACEB-4B6C-9C1A-9CB7ED045379_zpsmtxetl3h GenevaCustoms-custom mud mower - Page 2 B3153F68-62EA-4EB5-A19F-F73A45FC6D13_zpsy4kbbaey GenevaCustoms-custom mud mower - Page 2 13EC79EE-1A49-4E45-9F49-308F65E2839D_zps0ayfvt71
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeFebruary 18th 2015, 4:56 pm
Well hopefully I can finish welding up trannsmission mounts this week and have them done and get them painted and maybe paint the transmission. Senior project is over so now I can focus on projects I want to instead of rushing on the car lol
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeJuly 28th 2015, 9:22 pm
Started working on it again finally, defiantly won't be done for the build off but I'm not sure if or how I can move the thread back to the plain build area
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeJuly 28th 2015, 10:18 pm
You guys are giving up too easily. Come on, hammer on that thing!!!
GenevaCustoms
GenevaCustoms
PostSubject: Re: GenevaCustoms-custom mud mower   GenevaCustoms-custom mud mower - Page 2 Icon_minitimeJuly 29th 2015, 8:30 am
I'm starting to move in a couple of days lol
» Custom Mud Mower
» New snorkel and custom hood design for my mower
» Custom trail riding mower with no belt slip haha
» Craftsman LT1000 Mudder
» BUILDING THE MOWER - DAYS OF THUNDER RACE MOWER
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2015 Archive-
