| kawa"s 1993 honda cr80r restore and build | |
Age : 23 Join date : 2014-01-22 Points : 4571 Posts : 546 Location : north carolina
| Subject: kawa"s 1993 honda cr80r restore and build November 27th 2014, 10:30 am | |
| ok guys im a lil tired of working on mowers so i thought i would start with something different i have 2 friend that i know who was selling a cr80 and they were both 18 just betting it up which they should be on 250 s but anyways the top end went out and they didnt know how to fix it or what was wrong so they said you can have it if you go pic it up / so basically i got a free cr80 it a 2 stroke and the problem is that the rings have 2 inches missing from them and the piston has a chunk missing from it and the cylinder or jug is a slit so bad fromt the old rings just caring there own grovs into it if anyone has any cr80 parts please dm me and the rest of the bike is in good condition the shocks need new seals but i just got a suzuki lt230 and i work on that on my spare time so this is my spare spare time and i will post pics when i can | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 7th 2015, 3:49 pm | |
| The motor is in good shape but the top end is blown and it's got good tires it's going to need new front seals good brake pads and routers I painted the tank and took the old scratched sticker off the side pipe has a big dent in it but I sand blasted it and clear coated it to look better replanted the frame because the person before me got a red can of paint and didn't tape anything off and put new brake handles and panted some things here and there I took the top end out and half if the rings are gone and there is cuts in the cylinder from A to B there is no ring it all burned out the pipe thank goodness and c is a junk of piston missing I blacked out the rims with bed liner and recovered the seat and painted the front number plate I wanted to out some updated plastic on it but the radiator wouldn't fit so I'm going to get a full cr85 plastic kit so it will look cool but up todate and everything will fit but more pics comeing when I do more to it | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 8th 2015, 10:18 am | |
| You should be able to find a top end kit somewhere. Try checking ebay and amazon. Top end kits are usually around like 100 bucks or so... I'm not sure. Also I'd personally also leave the older plastics on it. Keeps the "original" look. | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 8th 2015, 10:26 am | |
| ( lawn mower mudder ) im going to send the top end to fred boaring company because my top end cylinder has grovs cut into so im boaring to into a 85cc and odering a wesico top end kit its like 95 dolors and my dad use to be the top mechanic for mike micdade and broc tickle so he had to send out many motor to be built back up because they would break bikes all the time so the freed company is going to boar my bike for 50 bucks | |
Doug Site Owner
802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3758 Posts : 146 Location : Vermont
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 8th 2015, 7:44 pm | |
| I'm a big big fan of two stroke bikes wish I had one, but only 80cc? Wow there are chainsaws bigger than that. And it's water cooled, never would expect that from a 80cc. Awesome bike! | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 9th 2015, 12:39 pm | |
| yeah all two stroke are suppose to have a radiator but its a cool bike ( Doug fackler ) im building it so it will do good in trails but also be really good on tracks but im only 72 pounds so i don't need save it and when i mean by racing i dont race like pro i just have a 6 acer dirt bike track that kx100 and crf450 and 2 yz250 a 125 a ds80 so we race on my track and none of use are super good so its not but like ride on a rough trail fast | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 9th 2015, 12:42 pm | |
| 802 Customs Thu Jan 08, 2015 9:44 pm I'm a big big fan of two stroke bikes wish I had one, but only 80cc? Wow there are chainsaws bigger than that. And it's water cooled, never would expect that from a 80cc. Awesome bike!
your right it is kinda a low cc but when it was still running with only a half blow top end my friend had a 30 foot run up to a 30 foot long double and cleared it and he was 113 pounds so these old 2 strokes are beast | |
802 Customs Member
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 12th 2015, 11:46 pm | |
| - kawasaki220 wrote:
- yeah all two stroke are suppose to have a radiator but its a cool bike
LOTS of 2 stroke engines don't have a radiator and are "fan cooled", Obviously string trimmers and chainsaws don't have a radiator, but high performance 2 cycles used to commonly lack a water cooling system. I've grown up around snowmobiles, two of which were fan cooled. We had a Skidoo mxz 440, zx chassis, went like a bat out of hell, it was fan cooled but it overheated when it was above 35ish degrees and ran on 1 cylinder. I bomb around on a Yamaha Bravo 250 these days because its light and fuel efficient. At 18 hp I wouldn't call it high performance, but come on its only 250cc, from 1983 and was kind of meant to be a "work truck" not a speed demon. Its not too fast (around 50 mph on ice), rides like a dump truck with leafs and shocks upfront, bogey wheels with maybe 2 inches of travel out back. But damn it's fun, and for only having 18 ponies and a track that is worn down to like .5 inch lugs it pulls like a freight train. The little guy almost never gets stuck. They were made from 1982 to 2012, because of their drop dead reliability, give me some gas, oil and some Vicodin (for the back pain) and I'd ride the thing to Washington state and back; it wouldn't give me a lick of trouble. Its gonna be a sad day when the track ***** the bed because nobody makes a 94" track anymore. TIME TO LONG TRACK IT. Lol. | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 13th 2015, 10:37 am | |
| oh yeh but i meant alot of 2 stroke dirt bikes and yeh we got a snomoble its fast 75 mph on the high way on a 55 got pulled but yeh hate to know they dont make a track for it how about you make a thread for it here in the off topic | |
802 Customs Member
| Subject: Re: kawa"s 1993 honda cr80r restore and build January 13th 2015, 9:38 pm | |
- oh yeh but i meant alot of 2 stroke dirt bikes and yeh we got a snowmobile its fast 75 mph on the high way on a 55 got pulled but yeh hate to know they don't make a track for it how about you make a thread for it here in the off topic
Id rather have a long track anyway, I can get a 121 skid on eBay out of a Polaris or something for about $150, or I could do a factory long track swap. The sled was available with a 136 track. Fastest I've ever been on a sled was 97 mph, it was kinda crazy. I could have pushed it to 100 but the straight away was ending soon so I had to nail the brakes. I might make a thread on it some day, idk though. | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build February 5th 2015, 9:43 am | |
| so yesterday i got some things done on it i finished painting and clear coating the rims and all i need to finish the rims is spoke skins red and white ones and i also painted half of the frame silver because all the new dirt bikes have silver or chrome frames and in 1987-1999 honda made there 80cc dirt bikes with white frames witch look to old for me so half of the frame is painted i need to finish the rest and while i was board i made my own graphics just to see what graphics would look like on it lol pics comeing asap | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build February 5th 2015, 10:06 am | |
| Here is the pics but I finished the rims and in this pic I took the back off the bike to paint it silver Here it is painted silver The silver is so light you can barley tell it's painted but all the frame is going to be silver And this is what my bike is going to look like when done but mine is going to have a black motor | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build February 27th 2015, 9:55 pm | |
| Here's a little update I took the piston off the bike a week or to ago to just get things ready for when I get a new one but it's all groves up and scard but I should be ordering parts for the motor soon can't wait to buy them I'm ordering all this
Weisco top end rebuild kit Pro taper handle bar pad Pro taper grips New front and rear brake pads Unbrakable brake levers A new shift lever Spoke skins A full 2003 cr85 plastic kit A 2003 cr85 gas tank A 2003 cr85 seat A full custom graphics kit from decal works New clutch cable
And many other parts I'm forgetting but it's should all total out to be 450$ but I can get the money easily because I'm selling my 1987 suzuki lt230e quadrunner it's a nice quad so more update comeing when I get some
| Subject: Re: kawa"s 1993 honda cr80r restore and build July 17th 2015, 5:18 pm | |
| well guys im stil on this build, im in nc and I sent the cylinder to pa to get board and ported and I bought the piston and rings, bought new grips and a handle bar pad that goes in the middle, I also got the frame painted, cleaned out and bleded the brakes, re greased the bearings and axles, so over all ive got a lot done and its looking pretty good but I still got a lot more to do | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build July 17th 2015, 11:06 pm | |
| About how much is it to get something like this engine rebored? Just curious, I don't know anywhere local that would do small stuff. I could look it up I guess. Who are you using? | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build July 20th 2015, 10:01 am | |
| well it all depends on the brand bike, how old it is, because my 1993 cr80 cant be board it has to be drilled out and re sleeved but like a 2008 cr250 can be board so it kinda depends on the bike and with this bike I can boar it to a 110cc but im only going to a 85cc and there charging 250$ for building the cylinder race ready and giving me piston,rings,bearings for those, gaskets everything I need | |
| Subject: Re: kawa"s 1993 honda cr80r restore and build August 27th 2015, 10:02 pm | |
| WELL HERES A BIG UPDATE I guess I need to find some old pics but heres it is since the old pics ive got the plastic cleaned the frame painted black and the motor back in the bike with a new topend that's been ported and board with race performance stiston rings and pin and I bought oil for the bottme end and radiator fluid and gas so hopefully ill have it running in a week | |
