 Eh engine suggestions needed.
5 posters
Nathan43
Nathan43
Eh engine suggestions needed. Empty
PostSubject: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 20th 2014, 12:51 am
I need some advice on an engine choice for a project. It will need to be able to run 3 hydraulic motors, a couple of hydraulic cylinders, truck alternator power steering. You know that usual crazy idea.Twisted Evil     I mow a few yards and plan on picking up a few more, and want something for kicking grASS.
I mow for the small town I live in and use a nice Bad Boy mower with a 26hp Kawasaki watercooled engine and you have to run full throttle to keep those hydraulic rear tires from squeeling like a 10 year old hydro going up a hill.
Send me some links and ideas.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 20th 2014, 2:01 am
big vanguard or kohler, 25+ ponies, horizontal shaft
CornShuck4CE
CornShuck4CE
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 20th 2014, 9:12 am
I dont understand. Why you neef to run multiple pumps. You only need one.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 20th 2014, 10:04 am
I think I got lost in here somewhere. I don't see where he says multiple pumps are required.
Nathan43
Nathan43
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 20th 2014, 2:36 pm
I don't know how many pumps are needed. I just need to run around three hydraulic motors and 2-3 cylinders. Oh and a truck alternator and power steering.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 12:09 pm
i would run 2 pumps. one for the motors and one for the cylinders, depending on the size of the pumps.
Nathan43
Nathan43
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 12:52 pm
Yea I was thinking on running 2 motors on one pump and the other motor and cylinders on another. Depending on the pump I get of course.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 2:35 pm
thats not a bad idea either, you could probably cut back to 2 snowblower engines, like 11 or 12 horses or something along those lines, or... honda GX340
Nathan43
Nathan43
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 2:49 pm
Yeah I'm not sure. That would be a good idea though, but stuff like that is hard to come by around here. I'm just trying to decide whether to build it or not, as I have early ford broncos in my sight and they ain't cheap lol.
Moose
Moose
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 3:50 pm
Id suggest a perkins diesel engine and a big ass john deere pump. I recommend running at minimun 25% more gpm than what you require to operate the pumps at max capacity that way you arent running your engine at full rpm all day. 2 motors on one pump would be cool if itd work but your either going to have to find a way to sink the throttles or they will work against each other.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 7:29 pm
Hang on- are you talking about 2 engines DRIVING one pump, or are you talking one pump driving two hydraulic motors???
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 21st 2014, 10:01 pm
he means 2 HYDRAULIC motors on one pump (driven by one engine) and the other hydraulic motor and the cylinders on another pump driven by a seperate engine
Moose
Moose
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 22nd 2014, 12:01 am
Itd help if we had specifics... what size hydraulic motor? What power range? High torque low speed or high speed low torque? You can run motors and cylinders off the same pump not sure youd be using them constantly but my case 646 can run the loader and drive at the same time.
Nathan43
Nathan43
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 22nd 2014, 4:53 pm
Sorry should've been more specific. One gas/diesel engine will drive the pump(s). The pump(s) will drive 3 hydraulic motors and around 2 cylinders. I haven't gotten into the specifics on the system yet, but I'm planing on driving two different decks with two of the motors and the rear axle with the third.
One of the cylinders will be lifting the deck that will be in the normal position on any regular mower. And the other will lift the wing deck I am planing on putting on the front left side. Another problem I'm having is will the hydraulic motors be ideal to run the decks or not.
And I would also consider running two smaller engines on different pumps, not sure though.
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 22nd 2014, 6:42 pm
Hmm. One issue I foresee: Blade inertia. Is there a way to have the blades able to freewheel? There are times where they will "want" to spin faster than the motor can (or is) spinning them. This could be a bit ugly.
Nathan43
Nathan43
PostSubject: Re: Eh engine suggestions needed.   Eh engine suggestions needed. Icon_minitimeSeptember 22nd 2014, 8:55 pm
It will still run through the pullies on the deck or will that not matter? The hydraulic motor will be in about the same place as the engine. So would the belts account for the blade inertia?
» First Acoustic Guitar! Need Suggestions and Tips
» Honda HT-R 3009 mid engine rider engine swap
» color suggestions?
» Tire Suggestions
