 Utility MX
redzz02
Deluxe66
jamcco
jonjunk
MoMower
13 posters
Go to page : Previous  1, 2, 3, 4, 5
Deluxe66
Utility MX - Page 5 Empty
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeNovember 17th 2015, 5:23 am
Plan was to use white and red but because of timetable issues I desided to use workplace paint shop. There is only one colour available and it is black. It took only half an hour to paint all parts. So one lunch break job.
http://aijaa.com/T2zOaA
Utility MX - Page 5 14026802.t
I will add Silver to the hood and that´s it.
When I had rear axle at my hands I noticed that one important this has not been done = Brakes. Well I will add some rod to the varidrive rod somehow Very Happy one pedal should be enough.
Until next time ..........
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeNovember 26th 2015, 6:16 am
I have worked with brake issues and now tractor should have brakes. After testings some modifications might be needed but now it is bolt on and next issues. Here is photo about the system.
http://aijaa.com/Rg2C0J
Utility MX - Page 5 14035191.t
I welded short tube to the varidrive lever. Dimension should be so that brake rod is pulled only when pedal is pressed almost to floor. I welded an bolt to end of the rod so that there is some adjustment available. There is also one guide tube welded under the frame. This tube should control so that the rod is not between the belts and pulleys  Very Happy
Seat position adjustments has also started. This new position should give a bit more space to drive.
I found an warranty sticker under the seat and I am not happy about it so I will modify also that some day later Question
http://aijaa.com/dgMiLX
Utility MX - Page 5 14035192.t
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeNovember 30th 2015, 5:20 am
Change of plans I decided to aim for higher speeds so I made an rear spoiler
http://aijaa.com/IcoKiF
Utility MX - Page 5 14038853.t
Not really Very Happy seat modification is now ready for painting.
Next issue is to figure out correct belt lenghts. Plan is to use ropes and adjust the lenghts with hose clamps. After I have better guess about the lenghts then I will buy new belts and most likely correct ones at once Very Happy
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 2nd 2015, 5:34 am
I wanted to put the bonnet to see how it is looking and I like the look so far Very Happy
http://aijaa.com/I3MjBH
Utility MX - Page 5 14040689.t
Today I was wiring the lamp and making place for the battery. Almost done some work still.
Here is modified sticker.
http://aijaa.com/rzJZ4x
Utility MX - Page 5 14040690.t
This is much better I should have easy mails in future. I just call to the maintenance and wait at the atrium  lol!
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 9th 2015, 5:32 am
Small progress. New seat position is almost perfect for me so seat position issue done.
http://aijaa.com/l6XGAQ
Utility MX - Page 5 14045828.t
http://aijaa.com/iL6D8H
Utility MX - Page 5 14045829.t
I tryed to figure out the belt lenghts but I need to buy longer belt and after test drive I know is it correct or not. This varidrive system is too complicated to my brains Very Happy
If everything goes as movies I will have true test drive before Christmas. If this works I will make big enough Christmas package and push this under the tree lol!
I will study about the Youtube so maybe some video will be published.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 17th 2015, 5:35 am
All wiring done ( totally 6 wires and 2 switches but done anyway). Also front light is working with small 12V scooter battery.
Engine bolted and caples attached. Different and hopefully better belt is installed. Engine should be at running condition and tractor should move if I just add some gasoline.
Some work still to do but not so much:
- tow hitch brackets need to weld to the rear skid plate. So rear skid plate is not bolted yet.
- tow hitch has to make from some road car parts that I have
- wheels are not completely bolted. I need to find more car wheel nuts. I use those to cenralize the wheel to the custom made hubs
- some other issues that I do not know or remember Idea
I found suitable box for this Christmas present so now I just need to find big enough three and wait for the Santa Claus santa
http://aijaa.com/8SP8FG
Utility MX - Page 5 14052414.t
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 17th 2015, 4:04 pm
Glad to see this almost done, different build all around for sure. Perhaps another build in the future? Got some good experience on this one.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 18th 2015, 10:44 am
Thanks this was different project for me. I like this kind of project where you do not need do it according some regulations you just do it just the way you like.
I try to add photo with phone lets see how it goes
http://aijaa.com/Oa7pzK
Utility MX - Page 5 14053175.t
http://aijaa.com/6UwR1w
Utility MX - Page 5 14053176.t
Now you should see my four year old son driving and also photo about UtilityMX and Silver Thingy side by side. If you do not see you just need to use your imagination  afro
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 18th 2015, 10:48 am
At least I can see those so might even succeed.
And yes I have another projects in my mind but one problem is limited time. Maybe something in future?
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeDecember 31st 2015, 10:41 am
Now I had some time to focus on this tractor. After the carburetor was opened two times and pull start repaired also two times I was able to even drive  Smile I am clad that I made groove to the frame at carburetor area.
http://aijaa.com/ggQWqt
Utility MX - Page 5 14061622.t
First modification need to the custom steering is now needed. When the axle is tilted the steering arm can rotate 360 degrees. I need to add stopper also to the triangle shape frame. Now the stopper at the front axle are not limiting enough.
http://aijaa.com/xiDyBL
Utility MX - Page 5 14061623.t
Luckily pull start was able turn facing back.
http://aijaa.com/FKDRzl
Utility MX - Page 5 14061624.t
This tractor definately needs diff lock. Maybe some day I have learn how to do it.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeJanuary 28th 2016, 2:42 am
Hello all. No progress on this tractor area due to the quite cold weather ( from the beginning of this year to last week we had more than -20°C all time) and some other urgent issues. Now weather is lot warmer and maybe I have some hobby time this weekend.
Anyway I have some progress with the Youtube. I think that I have everything ready to post video afro
I have only old computer so I will try to work with phone. If everything goes as plan you might see some video next week of week after that or after x perioid of time Very Happy
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeApril 13th 2016, 3:40 pm
This might be the after x period of time but here should be two video links
https://youtu.be/8JDCkrJRBNU
https://youtu.be/BTW39ZhD90A
As you can notice some fine tuning is needed. Belt tensioner spring got loose so tractor stopped. Easy to repair no problem. Gear shifting is hard because of wrong belt lenghts or some other unknown reason. Acceleration should be easier to use. I think that both rear tires should rotate all time.
Anyway it was fun to drive and it is ready for next drive.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeJanuary 1st 2017, 10:40 am
New year with new inspiration. It took lot of time before I managed to repair this tractor but now it is running again. The rear axle bracket bended after driving at rock section. So after that rear axle pulley was not at line with other pulleys.
Now it is running and latest modification was a bit better gas lever. Not final but it is working.
http://aijaa.com/qWfLfy
Utility MX - Page 5 14311739
http://aijaa.com/LpbFDz
Utility MX - Page 5 14311740
Steering is so light that my two year old son can drive this also
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeApril 5th 2021, 4:45 pm
Hello all,
This tractor have been out of usage about two years. This year my oldest son tryed to get it run but there was some issues with the ice between piston and cylinder head.
So Honda out and something else in. This time we will try how should 110cc chinese atv engine work. This might be slow build but maybe some day we can drive this thing.
https://aijaa.com/LhWUz6
https://aijaa.com/8ZAg6U
https://aijaa.com/XliTFU
We will do it something like pictures above. I would like to make chain driven portal axle but I have limited amount of time. So original rear axle will be used this time.
Maybe ready before 2022.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeApril 8th 2021, 3:29 pm
Rear axle is now welded with some unfinished brackets. More supports must be done.
https://aijaa.com/5EGuBK
https://aijaa.com/Dc7kCG
Next I will calculate what sprockets should I use between atv engine and rear axle. Have someone done this kind of desing? What sprokets have been used and what was the top speed?
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeApril 11th 2021, 3:56 pm
I had couple of hours time for this project. I welded engine support desing number 1 with chain tensioner. Plan is to tilt the engine. Next I will try to get the engine running so that I see how the chain stays and is the ratio correct. Now there is 15 teeth at the engine and 8 at rear axle.
https://aijaa.com/DOJDxk
https://aijaa.com/tIFMfv
This is getting ready faster than I assumed. Of cource gear linkage for excample takes some time and so on.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeApril 15th 2021, 4:12 pm
Test run is made. This setup is only to find out the top speed. It seems that 15 / 8 sprockets was correct.
https://aijaa.com/2KSKNl
https://aijaa.com/269a6U
https://aijaa.com/Sk812b
Now it only needs some fine tuning.
Deluxe66
Deluxe66
PostSubject: Re: Utility MX   Utility MX - Page 5 Icon_minitimeMay 15th 2021, 1:46 pm
Now I had some time for this project. I bought an small  stick welding machine. I am not pro stick welder but still I started by welding the rear axle diff lock. After reassembly the rear axle seams to work. It is not rotating as easy as before welding but hopefully it is not an problem.
https://aijaa.com/LrrUfp
https://aijaa.com/fG2bSV
https://aijaa.com/7iVWEK
https://aijaa.com/miqaX6
Utility MX
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
» Murray Garden & Utility
» Utility Trailer
» My Utility Build
» Homemade 4x4 Utility Vehicle
» MUT: Murray Utility Tractor
