 Belt lengths
2 posters
Phatmatt
Phatmatt
Belt lengths Empty
PostSubject: Belt lengths   Belt lengths Icon_minitimeJuly 9th 2014, 5:05 pm
I was wondering, what are the most common belt lengths? I'm wondering because I want to know before installing my pulleys so that I don't end up with belts I can't find for my build. Thanks
Belt lengths Empty
PostSubject: Re: Belt lengths   Belt lengths Icon_minitimeJuly 9th 2014, 5:19 pm
Belts very a lot between mowers, and since you are changing pulleys, there is no real good answer. really, its anywhere from 70" belts to 100+" belts, and once inch could really be a deciding factor. if you had some rope around the same thickness of a belt i suppose you could bring that to tractor supply and measure it. our store has a belt measuring stick.
Phatmatt
Phatmatt
Belt lengths Empty
PostSubject: Re: Belt lengths   Belt lengths Icon_minitimeJuly 10th 2014, 7:48 pm
Alright thanks, I can always install some kind of adjustable idler to tighten a longer belt.
Belt lengths Empty
Belt lengths
» need help with belt
» In need of some belt help?!
» belt shrinkage
» Belt coming off
