 How To: Home-brew Peerless 700 Bigger Driver Sprocket
How To: Home-brew Peerless 700 Bigger Driver Sprocket  Empty
PostSubject: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 27th 2014, 10:53 pm
So heres how im doing my home made driver sprocket and it came out great.
What you need:
Sprocket you are going to use that has space in the middle of it like mine pictured
brake rotor that has the same splines as the output shaft of your 700, mine came from a MTD FNR trans.
a good tape measure or best tool is a dial caliper
Vice and a few c clamps
Welder, or u guess you could bolt it together.
Theres a few measurements you want to take before cutting:
how much your splined output shaft sticks out to the e clip groove
how wide your rotor is at the spines, so you know how long your spacer from the original gearbox sprocket will be
out how far the sprocket needs to be from the gearbox, like where it is on the output shaft.
How To: Home-brew Peerless 700 Bigger Driver Sprocket  10426711
Heres everything i have, the new sprocket, the rotor, and the old sprocket, cut to the appropriate length as a spacer on the shaft.
Lightly clamp and VERY CAREFULLY center the sprocket on the rotor, TAKE YOUR TIME, this is not a race and you do not want to mess it up, make it perfect all the way around.
Once center clamp it hard, i re checked mine to make sure it didnt move.
I clamped my rotor on both sides to make sure it was flat, then i welded it.
How To: Home-brew Peerless 700 Bigger Driver Sprocket  10488910
After that i welded the spacer i had to the rotor for more splines to grab i guess, and less wobbling on the output shaft
How To: Home-brew Peerless 700 Bigger Driver Sprocket  10494810
After that just throw it on the trans and put the e clip and chain on!
How To: Home-brew Peerless 700 Bigger Driver Sprocket  10384311
Moose
Moose
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 27th 2014, 10:59 pm
Nice! Though I would have bolted it together so that if the sprocket ever wears out it could be replaced :p
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 27th 2014, 11:03 pm
Yea i thought about it, thats why i didnt weld the inside lip. i have a bad relationship with drilling in metal  Mad  so grinding down welds shouldnt be to hard
Moose
Moose
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 27th 2014, 11:12 pm
Just keep in mind to use a split point bit go slow and use a lot of oil or wd40... Kinda gives me a idea for instructional videos might do a small tutorial page in here for working with metal in the general aspects
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 27th 2014, 11:16 pm
That would be nice, because i dont have a drill press and try to avoid doing it... always turns into a a big pain  Evil or Very Mad
Craftsman1998
Craftsman1998
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 28th 2014, 8:37 am
Nice thats really cool im sure this will help a lot of people i might do this with my peerless 700
Moose
Moose
PostSubject: Re: How To: Home-brew Peerless 700 Bigger Driver Sprocket    How To: Home-brew Peerless 700 Bigger Driver Sprocket  Icon_minitimeJune 28th 2014, 11:16 am
Lol been there just takes patience.
» Wanted bigger front tyres and bigger rims
» Daily driver?
» my daily driver 1993 Z71
» DeWalt 20 volt max impact driver
» 2004 F250 daily driver/ general update
