 Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL
the old guy
B440
dwcopple
Angchor
jsisti845
rarbaugh07
camomanusa
Mitch'sgarage
Craftsman1998
Moose
ThatOneTeen
Moloko
23 posters
Moose
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Empty
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 28th 2014, 7:16 pm
Thats not good lol not sure there would be a good way to mount it might have to make a adapter or something
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 28th 2014, 11:11 pm
Got to work on it for a bit tonight. Pulled the pull start off the diesel and modified the flange from the Kohler to bolt onto the Diesel.
Bored out the hole on the flange using a step bit.
[IMG]Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0325_zps73113d7a[/IMG]
Here is the diesel without a pull start.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0322_zpsf4e02b92
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0324_zps98e50b04
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0323_zps9203d2e7
Put a stud in the flywheel to act as a keyway for the flange.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0326_zps95e12e8d
https://www.youtube.com/user/FuelInjectionSucks
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 28th 2014, 11:57 pm
Moose
Moose
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 29th 2014, 12:37 am
sweeeeeeeeeeeeeeeeeeeeeeeeet! cant wait to see this thing tearing up the streets!
Craftsman1998
Craftsman1998
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 29th 2014, 9:50 am
thats going to be awesome and what direction do the kohler engines turn i can't remember. and i have a cub and i never checked lol. And once i put a motor in a cub not remembering kohlers turn the opposite way and i had 3 speeds reverse and 1 speed forward it was hilarious i almost wanted to turn the seat around and drive it backwards.  Laughing
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 29th 2014, 11:16 am
They turn clockwise, if my brain is working right.
rarbaugh07
rarbaugh07
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 29th 2014, 1:05 pm
They all turn the same way. The way cub transmission needs to turn the shaft has to mount to the flywheel side.
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 30th 2014, 9:39 pm
Well we passed the point of no return tonight. The tractor is officially ruined from this point forward.
I cut the frame, big time.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0329_zps1a0531c0
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0328_zps158c764f
Motor is STILL too tall.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0330_zpsd8475c69
Driveshaft angles up.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0331_zps670b41d1
Trying to clear the hood is a complete joke.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0333_zps82eedcfe
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0332_zps2b9b1d26
Going to go to tractor supply and try to get some u-joints and PTO shaft to make a new driveshaft that can angle to adjust for the height difference. Going to have to widen and reinforce the frame, which I expected.
The hood will have to be "notched" on the driver's side. It's fine on the passenger because that muffler is coming off when the turbo goes on.
jsisti845
jsisti845
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 30th 2014, 11:27 pm
I wouldn't notch the hood I would just put two cuts on each side and bend it up and put pieces of sheet metal on each side to fill the gap if you know what im saying.
Angchor
Angchor
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJune 30th 2014, 11:52 pm
Raise the hood to that height.
Or raise it to half that height, and you don't have to notch as much.
I don't think it would look terrible, notched, anyway.
Moose
Moose
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 1st 2014, 2:11 am
Take the fuel tank off and mount it under the front of the hood then you'll have clearance Clarence
Craftsman1998
Craftsman1998
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 1st 2014, 8:49 am
yeah i wouldn't notch the hood i would sooner run no hood then ruin a perfectly good one. but its your tractor you can do what you want.
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 1st 2014, 8:45 pm
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 1st 2014, 9:20 pm
maybe mount the tank on the front top of the engine (?) You'll figure that out. id hate to see the hood cut, original look is sweet.
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 2nd 2014, 7:56 pm
Turbo is going there, but I will see if there is room anywhere else to relocate it
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 2nd 2014, 7:57 pm
Worked on it a bit today after a trip to Harbor Freight.
Started widening the frame using 1/4'' angle iron I had and pieces of the original frame that I cut out (waste not want not). One side is done, now the other side.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0334_zps447cf8d8
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0335_zps6e268b10
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0336_zps416b9600
Clearance for the regulator and oil fill.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0337_zps5b02c9e4
Now the other side. Looks like the steering draglink may be in the way.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0338_zps260a97b5
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0339_zps1cd3b3b6
dwcopple
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 3rd 2014, 10:33 am
doesn't appear to be in the way. If it is, you could bend it or put a drop in it or relocate the arm on the spindle.
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 3rd 2014, 10:23 pm
Made up the other side of the frame. Welds turned up better through the thick 1/4'' metal. The other side I was using an extension cord not thinking. Cord was getting real hot, so I wasn't getting the power I should have.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0341_zps549d5b0a
Still might add some more bracing. The side I did tonight had to be heavily notched for the oil drain/filter and steering draglink.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0342_zps73623888
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0343_zps297a3cd2
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0344_zpse044926e
Cozy Cozy
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0346_zps339cdcf5
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0347_zpse48995ba
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0349_zpsc6782fde
Bonus picture of the horribly translated warning label I never posted.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0348_zps183110a1
B440
B440
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 4th 2014, 5:33 pm
Hmm, I think I could get fire to close the fuel filler. Hold my drink....
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 5th 2014, 1:50 pm
Diesel: Do Not Eat lol
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 5th 2014, 11:03 pm
Here is the driveshaft goodness. I forgot to take a picture of it out of the tractor, and I wasn't removing it again. It's in the video though. It's made from steering U-joints from a Toyota Four Runner and the stock Cub shaft.
Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 IMAG0350_zps9c4a96a2
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeJuly 5th 2014, 11:41 pm
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeFebruary 18th 2015, 9:53 am
Been a while, but finally had time to work on it again.
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeMarch 14th 2015, 10:04 pm
Started painting tonight. Should be less ***** looking next time everyone sees it!
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeMarch 15th 2015, 7:12 pm
Sweet, Can't wait! when is the turbo gonna be installed?
Moloko
Moloko
PostSubject: Re: Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL   Project time! 1966 Cub Cadet 123 Hydro - TURBO DIESEL - Page 2 Icon_minitimeMarch 16th 2015, 9:38 pm
I'm waiting until all the fab is done getting the motor to fit. Then once I see where I have room, I'll mock up the turbo.
» Volkswagen Jetta A2/MK2 Turbo Diesel Project
» Cub. 1211 hydro project
» Prancstaman's X1 Scorpion
» long time no see. need suggestions on my next project.
» 1966 Chevrolet c10
