 found a peerless 726 3speed
5 posters
jonjunk
jonjunk
found a peerless 726 3speed Empty
PostSubject: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 18th 2014, 3:09 pm
Found out my old snowblower which the blower was shot on had a 3speed peerless stuck inside, anyone looking for a chain drive trans you should check out your snowblowers maybe you'll see one.found a peerless 726 3speed IMAG0271
PostSubject: Re: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 18th 2014, 3:15 pm
Maybe a small go-kart kit from an old snow-blower! trans, axle, chain, and sprockets all in one shot!
camomanusa
camomanusa
PostSubject: Re: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 18th 2014, 4:41 pm
now i know to look when i see them
Moose
Moose
PostSubject: Re: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 18th 2014, 4:52 pm
Would make a nice gearbox
low
high
holy s**t
jonjunk
jonjunk
PostSubject: Re: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 19th 2014, 12:59 am
My plan is to use this as a gearbox for my golf cart, currently it has fnr on it's transaxle but I can just leave it in forward all the time or have 3 reverse speeds if I need it.
Then I will use either the 5hp from the snowblower or my 14hp kohler.
PostSubject: Re: found a peerless 726 3speed   found a peerless 726 3speed Icon_minitimeMay 19th 2014, 8:27 am
most of the 700's that are in snowblowers have dual outputs, which is great for us. you can run a sprocket to a chain then an axle off one output, then a brake and caliper on another output.
» Prancstaman's X1 Scorpion
» Hello, just found this forum
» Check out what I found on YouTube!
» Some tiny trucks I found.
» found these two gems today !
