 engine question
Craftsman1998
fullout1stgear
8 posters
fullout1stgear
fullout1stgear
engine question Empty
PostSubject: engine question   engine question Icon_minitimeMay 14th 2014, 7:22 am
I had a 18 HP Opposed that was only running on one cylinder .(9 HP) so if I put in a smaller engine, would it be enough to get my tractor around? Just for ridding around the lot
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 8:08 am
how small are we talking? i'd just figure out why it wasnt firing on both cylinders. probably a bad sparkplug or ignition coil
Craftsman1998
Craftsman1998
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 8:35 am
Yeah it might have weak or no spark and thats why its running on one cylinder. Pull your plugs out crank it over and look for spark if there isn't any try sanding your magneto if that doesn't work you might need to replace it.
fullout1stgear
fullout1stgear
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 10:54 am
The valve seats were done it is not an easy fix so I got rid of it
fullout1stgear
fullout1stgear
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:03 am
Well I shouldn't say got rid of but made a deal
then youre a goof.. valve seats arent easy? they most certainly ARE easy, the hardest part is getting the old ones out. ANYWAY, what size new engine are you getting
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:14 am
Valve seats sent easy at all, especially on a flat head, you need a shop to press the old ones out and press, clearance and check the new seats. Witch will cost more then a used twin.
fullout1stgear
fullout1stgear
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:32 am
I got a push mower from my neibor that might do just fine. Is it a bad idea?
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:35 am
i wouldnt.. way underpowered. its just gonna make you mad when you cant do the stuff you want to do
Moose
Moose
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:41 am
if it is just for driving around a mostly level surface youd be ok it wont pull wheelies but Im sure itd be better than sitting on the tractor and making motor noises
fullout1stgear
fullout1stgear
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:49 am
Lol yep
Angchor
Angchor
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 11:52 am
ROFLOL!!!
You havn't been spying on me, have you?  affraid lol!
Moose
Moose
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 12:21 pm
Nah thats just what I was doing when I didnt have a engine for the massey was bugging my dad to pull me around with the craftsman so I could make motor noises
PostSubject: Re: engine question   engine question Icon_minitimeMay 14th 2014, 1:41 pm
I'd say lap the valves and run the twin!
PostSubject: Re: engine question   engine question Icon_minitimeJune 12th 2014, 4:08 am
If valve seat is done, I am sure your mechanic wants 1,400 to 1,800 to repair the engine, follow the mechanics advice, he knows more than you do about heads, my friend in a auto parts store sold 20 heads a week for years now.
PostSubject: Re: engine question   engine question Icon_minitimeJune 13th 2014, 11:13 pm
Actually, you've got less than 9 horsepower on tap. You've got to figure in all that drag from pulling around the piston and stuff on the dead cylinder. Jest sayin.
engine question
» Honda HT-R 3009 mid engine rider engine swap
» B & S Which engine do I have?
»  engine will not run right
» Craftsman off road tractor
