| C125 Wheel horse | |
+7camomanusa TheBeal LAWN MOWER MUDDER kawasaki220 Angchor 1997 Murray Craftsman1998 11 posters |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5154 Posts : 1068 Location : New jersey
| Subject: C125 Wheel horse April 28th 2014, 12:19 pm | |
Last edited by Craftsman1998 on October 8th 2014, 12:06 pm; edited 1 time in total | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5448 Posts : 1311 Location : NW USA
| Subject: Re: C125 Wheel horse April 28th 2014, 1:51 pm | |
| nice! it even has quad tires alreddy on it! looks strong. | |
| Subject: Re: C125 Wheel horse July 2nd 2014, 10:05 am | |
| I wish i had some snow so i could test the plow | |
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4421 Posts : 491 Location : Index, Washington
| Subject: Re: C125 Wheel horse July 2nd 2014, 10:34 am | |
| - Craftsman1998 wrote:
- I wish i had some snow so i could test the plow
You have gravel! | |
Age : 23 Join date : 2014-01-22 Points : 4573 Posts : 546 Location : north carolina
| Subject: Re: C125 Wheel horse July 2nd 2014, 1:38 pm | |
| plow some dirt hay all them flowers i have saw would work just as good to JK | |
Age : 23 Join date : 2013-04-08 Points : 5211 Posts : 913 Location : Central Pa
| Subject: Re: C125 Wheel horse July 2nd 2014, 2:42 pm | |
| You can't ruin a plow like that pushing gravel. Those plows are designed for gravel, dirt, snow, and other loose materials. Now if you would go and start pushing chunks of concrete or something it wouldn't be as good. | |
| Subject: Re: C125 Wheel horse July 2nd 2014, 3:33 pm | |
| - kawasaki220 wrote:
- plow some dirt hay all them flowers i have saw would work just as good to JK
Lol ok ill just plow those flowers | |
| Subject: Re: C125 Wheel horse July 2nd 2014, 3:36 pm | |
| - LAWN MOWER MUDDER wrote:
- You can't ruin a plow like that pushing gravel. Those plows are designed for gravel, dirt, snow, and other loose materials. Now if you would go and start pushing chunks of concrete or something it wouldn't be as good.
I have a pile of dirt in my backyard ill try and push it later | |
Angchor Member
| Subject: Re: C125 Wheel horse July 2nd 2014, 4:53 pm | |
| LMM is right. Gravel will not ruin the plow. Nor will the dirt.
Just remember to take small 'bites' with the plow. If you try to use the entire blade to move even heavy snow, you can bend it.
Take tiny bites and then keep working up until you find the limit for the blade. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5719 Posts : 1402 Location : Central PA
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4581 Posts : 467 Location : Greensburg, PA
| Subject: Re: C125 Wheel horse July 9th 2014, 11:59 am | |
| looks good for 100 bucks! whats your plans for it (i skimmed through so i probly missed it lol) | |
| Subject: Re: C125 Wheel horse July 9th 2014, 9:10 pm | |
| - TheBeal wrote:
- How bout some pics of that car?
ok | |
| Subject: Re: C125 Wheel horse July 9th 2014, 9:11 pm | |
| - camomanusa wrote:
- looks good for 100 bucks! whats your plans for it (i skimmed through so i probly missed it lol)
I was thinking of making it a work tractor like for towing snow plowing things like that. | |
| Subject: Re: C125 Wheel horse July 10th 2014, 8:21 am | |
| that would be cool put like a boom on the back and a winch nice big bumper for pushing | |
| Subject: Re: C125 Wheel horse July 10th 2014, 8:25 am | |
- that would be cool put like a boom on the back and a winch nice big bumper for pushing
yeah that would be cool make it into a off road rescue tractor | |
| Subject: Re: C125 Wheel horse July 16th 2014, 1:48 pm | |
| The gas tank had alittle gas in it so i figured id let it run so i wouldn't have bad gas sitting in the tank. while it was running i found the tag for the model numbers it was hidden very well | |
| Subject: Re: C125 Wheel horse July 16th 2014, 1:51 pm | |
| Im guessing it from the 1980s because the last 2 numbers are 80 | |
55olds New Member
| Subject: Re: C125 Wheel horse July 16th 2014, 6:28 pm | |
| I think they were made in the 1970's actually. | |
| Subject: Re: C125 Wheel horse July 16th 2014, 10:27 pm | |
| - 55olds wrote:
- I think they were made in the 1970's actually.
hhmm really all the c125s i saw online are from the 80s | |
B440 Member
Join date : 2014-01-22 Points : 4206 Posts : 226 Location : Thompson, CT
| Subject: Re: C125 Wheel horse October 8th 2014, 12:33 pm | |
| Why did you take the ATV tires off? It looked like you only needed tubes for them. | |
