| Jonjunk's Craftsman mud machine | |
+9The1963Chevy willis923 Ariens YT11 Angchor camomanusa richie thomas LAWN MOWER MUDDER craftsmancole jonjunk 13 posters |
jonjunk Member
Age : 31 Join date : 2014-03-21 Points : 3978 Posts : 66 Location : Montrose, MN
| Subject: Jonjunk's Craftsman mud machine April 12th 2014, 1:03 am | |
| Hi guys new to the forum, this is my first post but I have been reading the forums a lot and helped me thru my builds, I have a craftsman lt that I am building currently, it was a hydro 17hp Intek single, now it has been swapped for a 5 speed peerless (920?) Out of my jd stx38 that was a small machine and very flimsy, I find the craftsman easier to work on.
So about the tractor, got it for free and began working on it this week, dropped the, hydro put the 5 speed in it with a new 4 in pulley the stock belt was used by making my own trans mounts I could just slide the tranny back till it was tight enough. Made my own shift linkage hooked to the deck lift bar which works great now, rewired the whole tractor to push button start, separate choke cable, also cleaned the carb.
I plan to do a lot more to it like swap the hood out for a more attractive one(anybody got one?), switch to handlebar steering using a set off of a Polaris snowmobile which has a master cyl, hand warmers kill switch and throttle attached I plan to use all of those. Also switch to 25x12x12 tires that I already have, also have a 12" rim set that the centers need to be cut out of (stuck axle). Larger front tires(the rears), and possibly front brakes, winch. And lock the front axle and differential of course.
Also the clutch shakes like mad when released, I believe there is a flat spot on the pulley but I haven't looked yet.
Greetings again from central Minnesota.
I'll post pics asap
Age : 25 Join date : 2013-04-05 Points : 4964 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 2:45 am | |
| I dont know your driving habits, but I personally wouldnt risk snapping my 3/4" axle in half with 25x12x12s. I would look around Craigslist for a Murray gt or something like it that has a geared 1" axle. These tractors usually have 5 lug 12" rims and can withstand those tires. | |
Age : 23 Join date : 2013-04-08 Points : 5211 Posts : 913 Location : Central Pa
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 7:24 am | |
| Agreed. Anything over 21'' tall tires is just too much for 3/4'' axles. I personally would get a peerless 820 if I wanted to run those tire sizes. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6402 Posts : 1434 Location : east dublin georgia
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 5:58 pm | |
| maybe, but i haven't snapped anything with mine on dixie, so i dont see what the worrying is about, some people dont think they work, yet some people say they do. i say go for it, | |
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 6:00 pm | |
| Thanks for the input guys, I'll have to see what I can find at the tire shops junk pile next time I go if theres any 8" tires then I won't have to modify a rim, but right now I have 16" tall knobbys on now but wanted a little bigger so I can put something big on front too. | |
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 6:07 pm | |
| i say go for bigger tires, i ran a murray with a mst-206 for months with 25" atv tires, and i beat the hell out of it, was pulley swapped to a 1:1
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 6:18 pm | |
| My other idea was use a 9"rim with homemade hubs because 9inch is a little easier to find around the farm I already have a pair of brand new Carlisle strykers that are 25-12-9 for my 3wheeler that I never use on it anyway , most tires I use besides are junk lol, I also have a pair of 22-11-8 that would currently fit but one has a huge tear and they don't match so I would have to patch that tear with extra rubber then foam fill it lol.
Besides that I have a set of bald 20-11-9 holeshots that we plan to stud, and the 25-12-12 Carlisle (stock Polaris sportsman tires) that were all free | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4581 Posts : 467 Location : Greensburg, PA
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 12th 2014, 8:51 pm | |
| Definitely free is the best word, both mowers I got free along with all the tires / extra rims , even the pieces to build my one homemade trailer, and the 12" craftsman rims/ tires, that's why I dont want to buy an 820.
I usually use gently used (scrap) steel and used wiring for my tractors, hope to find the brakes out on the pile too from a junked motorcycle that is already been torn down. | |
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 12:19 am | |
| Spent the day working on my craftsman today, did the front pulley mod using the deck pulley, clocked it at 17mph which is plenty, worked on my friends atc200. Then later my friend drove the craftsman into the field for a quick mud run, got stuck and the shifter ended up getting jammed internally, so turns out after we split it the small pin that pushes the shift collar back and forth snapped off so he is going to see what he can do to fix it being a welder but I don't think it's fixable now, unless I order a new part, also one of the front trans hanger bolts cracked off the corner of the case probably when my other friend pulled a wheelie and fell off the back, very comical sight but did a little damage. Also adjusted the governor so I can go past half throttle not too fast though. I would have taken pics but we didn't get out to the woods to rise today Oh and fixed the idler pulley that had two flat spots in it the inner circle was now shaped like a baseball field lol, now there is a steel idler in it's place | |
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4421 Posts : 491 Location : Index, Washington
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 4:07 pm | |
| - jonjunk wrote:
- so turns out after we split it the small pin that pushes the shift collar back and forth snapped off so he is going to see what he can do to fix it being a welder but I don't think it's fixable now, unless I order a new part,
Grind the fan surface, level, at the site of the pin. Drill a small hole. Tap it. Install a bolt of the right size to replace that pin. Make sure the bolt is as high a grade of bolt as you can find. Weld on the top side, if need be. | |
Age : 27 Join date : 2012-10-31 Points : 5166 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 8:13 pm | |
| I like the sound of your build, Have you chatted with WellThatSuprising? he is in Bethel MN, and what part of central MN are you from, I was born in Isanti County.
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 8:34 pm | |
| Montrose mn, no updates on the mower today but ordered a front tire for my Honda 200x it's a Carlisle at489 and a tube for my brand new Carlisle strykers that hopefully will be usable on my mower and 200x if I make hubs for the mower out if rims with the centers cut out. | |
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 8:46 pm | |
| Sweet, I would like to see some pics, if you can get some let me know and I can get you my email and I can post them for you if you would like.
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 15th 2014, 10:12 pm | |
| I wish I would of snapped a few yesterday but now its torn down again with the rearend out of it, although just got news that chad was able to fix the trans piece we just have to grind it to fit then we'll be golden. | |
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 18th 2014, 6:41 pm | |
| Ok got the mower back together and running, works good now and the trans mounts are a lot stronger. Now needs some belt keepers or just never push in the clutch lol! | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5763 Posts : 1408 Location : Galway NY
| Subject: Re: Jonjunk's Craftsman mud machine April 18th 2014, 6:49 pm | |
| bolts work great for belt keepers. drill a hole through the frame, about a 1/4 inch away from the pully, send a bolt in so it keeps the belt on the pully | |
jonjunk Member
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 25th 2014, 11:47 pm | |
| Found some goodies at the pioneer power swap meet today in Le Seuer, MN. I got a peerless, not sure of model yet but it's different than my 930, possibly an msg 205. Played $10, I wish I would of picked up my other option but it was not as easy to get to the car and it was $20 although it came with rims, and was a 3 spd with high/low. I also got an amp meter and a very small fuel tank for $1 each. | |
The1963Chevy New Member
Age : 26 Join date : 2013-10-09 Points : 4066 Posts : 4 Location : Deerfield, Utica NY
jonjunk Member
| Subject: Re: Jonjunk's Craftsman mud machine April 25th 2014, 11:54 pm | |
| No too dark now, It has 3/4 inch axles and a tall shifter lever. Looks very similar to the pics I just looked at online.
Also picked up a 3hp Briggs parts motor for $5. | |
| Subject: Re: Jonjunk's Craftsman mud machine April 26th 2014, 12:00 am | |
| i cant remember if the MST-205 has 3/4 axles or not. i dont think it does, but i could be wrong. there should be a tag on it somewhere
jonjunk Member
