| Mines bigger than yours! | |
+5Moose richie thomas willis923 Doug redlinemotorsportts 9 posters |
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Mines bigger than yours! March 26th 2014, 8:28 pm | |
| Goofing around in vocational diesel class, and see this on the shelf! Probably for a teaching demo. But holy rocker arm batman, i 'bout pooped a kittin on the spot! ![Mines bigger than yours! 19205310](https://i.servimg.com/u/f56/18/18/82/33/19205310.jpg) | |
Doug Site Owner
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | |
willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
richie thomas Veteran Member
![richie thomas](https://2img.net/u/2812/37/66/46/avatars/156-8.jpg)
Age : 29 Join date : 2011-08-04 Points : 6326 Posts : 1434 Location : east dublin georgia
Moose Established Member
![Moose](https://2img.net/u/2812/37/66/46/avatars/1358-86.jpg)
Age : 35 Join date : 2014-01-12 Points : 4877 Posts : 919 Location : Defiance, Ohio
Craftsman1998 Veteran Member
![Craftsman1998](https://2img.net/u/2812/37/66/46/avatars/1167-45.jpg)
Age : 26 Join date : 2013-10-30 Points : 5078 Posts : 1068 Location : New jersey
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 27th 2014, 10:48 am | |
| ![Mines bigger than yours! S2xCq6Vl](https://i.imgur.com/S2xCq6Vl.jpg) Exhaust valve from a 16 cyl twin turbo charged monster that runs off natural gas :p ~3000 hp at 800 rpm They use them on the pipeline where my mom works | |
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 27th 2014, 2:30 pm | |
| ya need 2... some splines and a bolt hole circle drilled in the valve head, and that's a perfect axle! | |
Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 28th 2014, 10:49 am | |
| Back when I did real work at work... couple of crankshafts, 28,000lbs each. From a 2000 ton stamping press. ![Mines bigger than yours! Pbucket](https://2img.net/h/illiweb.com/fa/pbucket.gif) My record lift was 220,000lbs, slides from a stamping press. | |
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 30th 2014, 3:00 pm | |
| Pretty amazing if you think about it. From those mini model V8 engines and r/c airplane engines to the huge diesels used on ships, all working basicly the same. That exhaust valve would make a nice lamp... | |
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 30th 2014, 3:05 pm | |
| More to add to this section i saw today... Is this strong enough for my racing mower?? ![Mines bigger than yours! 19725110](https://i.servimg.com/u/f56/18/18/82/33/19725110.jpg) Some chain, 10" wide at a link ![Mines bigger than yours! 10152610](https://i.servimg.com/u/f56/18/18/82/33/10152610.jpg) | |
![Mines bigger than yours! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mines bigger than yours! March 30th 2014, 5:53 pm | |
| looks like the chain they use at the tractor pulls in bowling green lol have seen it break once or twice | |
