| Project Long Travel | |
+7willis923 83ratrodmurray Doc Sprocket redlinemotorsportts Moose Lawren Wimberly Jedi 11 posters |
Jedi Member
Join date : 2013-11-27 Points : 4065 Posts : 44 Location : Georgia
| Subject: Project Long Travel February 26th 2014, 1:28 pm | |
| This is what I started with, a mostly stock 2004 Troy-Bilt Pony An explanation of project Long Travel- The Goal: The goal is to take my 2004 Troy-Bilt Pony (I bought new) and add double A-arm independent suspension to all 4 corners and to drastically increase it’s top speed, and off-road capabilities and to improve it’s overall performance, usefulness and fun factor. The Details: *The engine is a 17.5 hp Intec single, this will likely remain the same. *Power transfer- The mower’s current Vari-drive system will be scraped. The plan is to use a Comet 40/44 Series Torque Converter System (or equivalent) from the motor to a jack-shaft where the driven clutch will mount. From the jack-shaft a chain will lead to the input shaft of a Peerless 700 5-speed. From the output shaft of the 5-speed a chain will lead to a 1 inch live axle. *Front suspension- I just finished grafting the front suspension from an old China made 4 wheeler I have onto the mower. *Rear suspension & axle- This will be somewhat typical of this style double A-arm. A non-adjustable, bearing mounted center carrier (drive chain adjusted via a chain tensioner.) the center carrier (made of 1” shaft material) will carry the drive sprocket and disc brake rotor and will be book ended by 1” universal joints. Then, suspended by the A-arms (which I will make) will be more 1” shaft leading to another U-joint and a hub carrier and hub. Coil-overs again for the shocks. This is fairly standard stuff for off-road buggies and should work well for an off-road mower. *Brakes & steering- Special attention will be paid to these 2. The brake will be rear hydraulic disc… a juice brake… the front are mechanical drum. The steering will be reworked for strength and reliability. You absolutely never want your steering or brakes to fail at speed, no one wants to be an unwitting passenger of a greased pig tied to a lightning bolt… I will post updates as progress is made...... but this will take some time They say that in any great endeavor half the struggle is just showing up… so here I am.
Age : 57 Join date : 2013-12-21 Points : 4807 Posts : 744 Location : Salem Illinois
| Subject: Re: Project Long Travel February 26th 2014, 1:45 pm | |
| Big build ahead, I wanna wish ya luck and I'll be watching this build closely. Big task means great opportunities for learning! | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4953 Posts : 919 Location : Defiance, Ohio
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 2:04 pm | |
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 2:17 pm | |
| some great design and machining skills goin on there! ingenious use of the roller chain and sprockets... I'm assuming a third sprocket gets connected to the steering wheel?
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: Project Long Travel February 26th 2014, 2:20 pm | |
| Holy moley dude! all that fab work looking great Nice work so far!! | |
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 2:49 pm | |
| Thanks Lawren, Redline.... yes a third sprocket is used. Originally The third sprocket was on the steering column but on this I'm thinking it will be mounted on its own bearing supported shaft which will in turn be linked to the steering column by a rod. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
| Subject: Re: Project Long Travel February 26th 2014, 5:04 pm | |
| Looks pretty dang good so far. Please tell me you're going to engineer some droop into the front end. All too often, I see people setting these up so that ride height is at full rise. Just wrong, it is. | |
83ratrodmurray Member
Age : 29 Join date : 2013-07-05 Points : 4294 Posts : 94 Location : Kentucky
| Subject: Re: Project Long Travel February 26th 2014, 5:42 pm | |
| very interesting build that thing should be unstoppable when it's done. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5763 Posts : 1408 Location : Galway NY
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 7:25 pm | |
| Doc, yes there will be droop, I have to do some figuring on the rear suspension. I have to determine everything based from the full droop of the rear suspension. The universals (pictured) have a max operating angle, I need to stay a few degrees away from that at full droop. I would guess maybe 30% of suspension travel will be droop but I've never done this before on a mower so nothings carved in stone. the u-joints on the left will be used on the rear axle. (sorry about blurry pic) Lots else to figure, I have to check ackermann, it may be close enough to leave alone. The shocks are also a complicated item that can make or break the ride, and they're pricey. Air shocks are the best as far as adjustability but expensive. So expensive that I started modifying truck air shocks for off road buggy duty with good results. This is a air shock for a ford ranger. I fab expansion chambers to increase volume, you can change the volume with filler plates mounted on a threaded rod inside the chamber. You can also control compression and rebound with inline metering valves. If I could find very small car air shocks I might could use them on this project......maybe.... | |
| Subject: Re: Project Long Travel February 26th 2014, 8:17 pm | |
| That sounds pretty good to me. 30-50% seems reasonable, I'd call 30% a minimum. I'm no suspension engineer, but have lots of notes. Just be sure to set spring preload with weight on it to simulate the engine, driver, etc. | |
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 8:25 pm | |
| Ya, on motorcycle powered buggies I shot for 40-45% droop which was a recommendation for actual 'dune' buggies that can see a lot of air time. | |
| Subject: Re: Project Long Travel February 26th 2014, 9:05 pm | |
| Makes sense. Do you have the operating angle specs for your U-joints? | |
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 9:32 pm | |
| - Doc Sprocket wrote:
- Looks pretty dang good so far. Please tell me you're going to engineer some droop into the front end. All too often, I see people setting these up so that ride height is at full rise. Just wrong, it is.
For those out there watching this thread with interest that may not get Doc's point.... If you set up a sprung suspension so that the ride height is all the way at the top, every time you hit a bump, the springs hammer the suspension back to the top, after the bump passes. Aside from making for an uncomfortable ride, it's hard on the parts, and may as well not be sprung at all | |
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 9:46 pm | |
| Right, most important if your suspension is at full droop (or near it) when loaded and stationary your wheels will spend a lot more time in the air and not on the trail where you need them. Just taking a sharp turn at speed will lift a front wheel off the ground. | |
Join date : 2013-06-01 Points : 4812 Posts : 578 Location : West Virginia
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4703 Posts : 356
Jedi Member
| Subject: Re: Project Long Travel February 26th 2014, 10:42 pm | |
| TroyBilt, ya they are real brutes. I put those big tires on the back first to pull ground engaging equipment and I can't believe the things it's done and never broke! | |
Jedi Member
| Subject: Re: Project Long Travel February 27th 2014, 10:12 pm | |
| Ok, I believe I've decided on the steering setup. 1st I'm leaning towards using handlebars instead of a steering wheel. Lots of hand wringing over this. I like the idea of using an ATV thumb control for the throttle and operating the front brakes from the stock lever simplifies things as well. Based on this decision I came up with this as the general strategy. Not sure this makes sense to anyone but me. Basically a bracket welded to the steering shaft, a link from that to a bracket mounted to a bearing supported shaft. The shaft will go down thru the frame where another bracket will be mounted. A link from that leads to the rack. Links will have heim joints. I think I have everything I need to do this so I might get to it this weekend. If you see any issues with this please let me know. Oh, and yes I got rid of the roller chain on the rack and will modify it for a link mount. | |
Jedi Member
| Subject: Re: Project Long Travel March 1st 2014, 11:35 pm | |
| Had a little time tonight so I fired up the shop's heater and went to work. I think I have the steering rack in position. Will know tomorrow when I will try and complete the new steering. | |
| Subject: Re: Project Long Travel March 1st 2014, 11:40 pm | |
| I'm thinking it might be hard to turn. Guess we'll see. Been lookin forward to some more progress on this! | |
