| Moose's Diesel Massey | |
+21MurryMaddnes craftsmancole Thunderdivine TheRainbowBoxer richie thomas Craftsman1998 B440 redlinemotorsportts TroyBilt Pony willis923 T-Dub13 LAWN MOWER MUDDER Jedi Stretch44875 Doc Sprocket WilliesBuilds Lawren Wimberly 1997 Murray Doug Creepycrawler Moose 25 posters |
| Subject: Re: Moose's Diesel Massey March 7th 2014, 3:48 pm | |
| emergency room, by law, can't turn you away for something like a back injury... don't let the insurance thin stop you if ya need it | |
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4574 Posts : 540 Location : Central MA
| Subject: Re: Moose's Diesel Massey March 7th 2014, 4:33 pm | |
| - Lawren Wimberly wrote:
- emergency room, by law, can't turn you away for something like a back injury... don't let the insurance thin stop you if ya need it
Yeah, Obama will sssppphhhhhhhhhhbbbbbb....Nevermind. Don't want to get into that now hahah! | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4953 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Moose's Diesel Massey March 8th 2014, 3:58 pm | |
| Ok so without hurting myself to bad I swapped the front axle need to make a bushing and spacers for it also need to cut the tierod and get heims for the ends to link it all together the front axles are 3/4" so pretty sturdy for what I wanna do though at almost 45 degrees of articulation its gonna need shocks lol She is flexible lol Nice wide stance too! | |
Age : 57 Join date : 2013-12-21 Points : 4807 Posts : 744 Location : Salem Illinois
| Subject: Re: Moose's Diesel Massey March 8th 2014, 4:29 pm | |
| Tire clearance may be an issue as well at full articulation with the sheetmetal installed... may wanna watch the exhaust and tire clearance when ya get to it
| Subject: Re: Moose's Diesel Massey March 8th 2014, 4:48 pm | |
| Exhaust shouldnt be a issue its gonna be routed to the underside where it will run into the pipes | |
| Subject: Re: Moose's Diesel Massey March 18th 2014, 12:42 pm | |
| Update!: Ok so I have been busy practicing welding and trying to get back into the groove (it isnt working but w/e gorrilla welds!) I bought some angle and a piece of flatstock burned them together real nice then drilled my holes ground for clearance and got them attached to the frame! I messed around with it last weekend and today the only 2 warm days so far \o.o/ yeah... she sits pretty high lol plenty of clearance for the executioners! More than likely going to have to make a reese style 2" dropdown hitch so I dont end up flipping her when I go to pull stuff Pulley hangs pretty low but that shouldnt be a issue I will get around to making a tranny plate sometime to cover everything I am going to reuse the tie rod but instead of the little ball cup joints they will be replaced with heims Fits like a glove! a glove that needs some grinding and idlers to run properly lol... The shifter is bent in a kinda S shape so I will more than likely have to heat it up and straighten it out to get enough clearance to shift it and not end up with a ball buster My crappy ass welds :p but they hold! Annnnnnnnnd just as a reminder of what she was and what she is! | |
| Subject: Re: Moose's Diesel Massey March 18th 2014, 12:50 pm | |
| yeah that bit in front of, and to the right of the shifter looks like a knuckle buster too
Lookin like a tractor again though moose! | |
| Subject: Re: Moose's Diesel Massey March 18th 2014, 12:57 pm | |
| Lookin pretty stout! Is this what the Harley exhaust is going on? | |
| Subject: Re: Moose's Diesel Massey March 18th 2014, 1:02 pm | |
| yup and yup lol already busted my knuckles enough on this baby and yeah shes gonna sound as sexy as she looks | |
B440 Member
Join date : 2014-01-22 Points : 4206 Posts : 226 Location : Thompson, CT
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: Moose's Diesel Massey March 18th 2014, 3:29 pm | |
| Very nice! Executioners will be right at home. Lets see a flex pic! | |
| Subject: Re: Moose's Diesel Massey March 18th 2014, 4:21 pm | |
| I wanna see those Harley pipes stickin up loud and proud LMAO! pardon the 60 second drawing. | |
| Subject: Re: Moose's Diesel Massey March 19th 2014, 1:31 am | |
| Heh I'll get a flex pic in the morning if is nice enough need to get collars for the spindles so I can keep the front tires from falling off. I like the stack idea t dub I'll have to see if I can run the pipes out either side or turn the motor and just make some belt guides! May have to get Doug to get some pics of the work gt's belt setup. | |
WilliesBuilds Member
Age : 29 Join date : 2013-06-19 Points : 4571 Posts : 329 Location : Florida
| Subject: Re: Moose's Diesel Massey March 19th 2014, 10:42 am | |
| lol shes gonna be a earth mover thats for sure I am kinda wondering if the 1-1 ratio on the pulleys is going to be to high... | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5154 Posts : 1068 Location : New jersey
Age : 37 Join date : 2013-07-02 Points : 5021 Posts : 731 Location : Logan Ohio
| Subject: Re: Moose's Diesel Massey March 20th 2014, 10:57 pm | |
| Ive ran a few of those trannys, all with 6 inch motor pulleys and stock tranny pulleys. gives ya a nice speed for working, and still fast enough to not be bored just getting from place to place. also I dont know if you have plans to put another mount up top like the factory uses, but I would highly recommend it, we had problems with ours when we first started riding sears and would be two lazy to put the top bolts back in, other than that it looks good | |
| Subject: Re: Moose's Diesel Massey March 21st 2014, 2:27 am | |
| Yeah the top mount is more than likely going to be a piece of angle not sure yet lol I am running a 10 inch pulley to the stock 9.750 pulley :p | |
| Subject: Re: Moose's Diesel Massey March 23rd 2014, 7:03 pm | |
| Holy travel batman! Looks sweet, still lots of room at full flex. everything looks really well done and not half-assed! | |
| Subject: Re: Moose's Diesel Massey March 23rd 2014, 9:26 pm | |
| I been taking my time with her I wanna make sure she is bullet proof when I get done lol | |
| Subject: Re: Moose's Diesel Massey March 25th 2014, 1:09 pm | |
| Things left to do: (In no specific order)
Lock diff Paint Motor rebuild etc Figure out the clutch Gas pedal Mount tires Machine brass flange bushings Plumb exhaust
Thats all I really remember atm lol will keep you guys updated | |
| Subject: Re: Moose's Diesel Massey March 26th 2014, 11:26 am | |
| Looking great Moose! Pipes are going to set that thing apart from the crowd. I like the steering linkage. Excellent engineering there! | |
