| Street mower | |
+3Ford Boi dangeroustoys56 Trcustoms 7 posters | |
| Subject: Re: Street mower November 11th 2010, 3:06 pm | |
| Thats exactally how my MTD felt - seemed super fast in the backyard, then was like slow going wot. The murray was never like that- was fast in both places.
I think that 6 speed trans from the murray might find its way into the MTD soon enough....
| | | Trcustoms Member
Join date : 2010-09-19 Points : 5410 Posts : 225 Location : Bear,De USA
| Subject: Re: Street mower November 23rd 2010, 6:58 pm | |
| Did a few more mods. I added a front bar to keep the engine safe if i hit something and i put a bigger front pulley on it, i had a 4.5 on the front now i have a 6.5 and the back is still a 5". I need to add more gear oil and fix my leaky axle seals cause the gear oils just leaks rite out then the tranny gets loud. She does around 25-30 now instead or 15-20 i'd say. | |
| | | Trcustoms Member
| Subject: Re: Street mower January 8th 2011, 12:56 am | |
| Long time no update!
I'm thinking about putting the rear tires from the simplicity on this one and putting the front pulley back to where it was. I miss off roading mowers since i got my atv, I ll give the atv a break and play with this mower for awhile. | |
| | | XJeric Member
Age : 31 Join date : 2012-08-03 Points : 4538 Posts : 39 Location : port hadlock,wa
| Subject: Re: Street mower August 4th 2012, 6:07 am | |
| nice mower but id lower it so the chassis is 4" of the ground and have a machine shop make you a widened axle for the trans axle and go to bmi carts get some good spindles and lower it down for a lower cog and ebay for a tether kill switch and support the axle with pillow blocks hear is a pic of one of my racers i got 3 lime green ones and know how to do chassis setups and engine mods | |
Age : 49 Join date : 2012-04-23 Points : 5702 Posts : 1091 Location : Galion, OH
| Subject: Re: Street mower August 6th 2012, 8:55 am | |
| This is the angle that will get you hurt at high speed. With the camber you have on that axle, once you get it up to speed, it will start that dreaded hunting right to left. Our mowers have 0 degrees camber. The front axles on ours are custom made, but there are stock axle assemblies you could fit in there that have no camber. | |
| | | | | Street mower | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
