k. i want this. 4 cylinder cummins turbo diesel chevy s10. 4x4. well id rather build my own and make it a mini tank of a truck tho. all it needs is a more solid frame. steel bumpers and that would be indestructible.
Age : 27 Join date : 2013-03-18 Points : 7484 Posts : 3131 Location : raleigh nc
k2500 understands. the bed is where its at. extended cab 6ft bed. and i could do whatever the heck i wanted to do to this thing. frame reinforcements and solid steel bumpers. a winch. roll cage. run it on like 30's with 16" rims. that may be to big for that. idk. it would get around 20 mpg. maybe more if i was lucky. 400ft lbs of torque 150hp.
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5372 Posts : 1135 Location : Southern Florida
i guess if a bed is what you want so be it lol. just thought you wanted to be good offroad truck LOL jk. Jeeps and ls engines are the answers in my world
Age : 30 Join date : 2013-03-18 Points : 4926 Posts : 618 Location : loxahatchee, florida
or maybe take a chevy 2500 frame with 1500 suspension and a cummins 6 cylinder. i think thats 600ft-lbs and idr the hp rating on those engines. id get a adapter plate for a allison transmission to mount to the engine and run 1 ton axles under it. i would like 1500 suspension instead of 2500 as its obviously softer supsension. lighter weight. all i would carry is tools and passengers. id still stick too ext cab and 6ft bed.. and its all on what you like red. i like my chevys. not a big jeep fan honestly.
Yeah maybe some 2500 with a solid front axle. That will save you a ton of hassle
my point exactly red. lol. solid axles front and rear. i think the s10 would be less cost tho as its small and the ford 5 speed bolts right on. gotta love stick shift
if i did the s10 tho id want to swap in custom length 1/2 ton solid axles front and rear. and id love to use a chevy transmission so i could keep everything simple and chevy based. just bolt the engine in and go kinda thing. you know
Join date : 2013-06-01 Points : 4811 Posts : 578 Location : West Virginia
ive come to the conclusion. when i build this its going in a 2nd gen dodge ram 1500 ext. cab with 1 ton (dana 60) axles. a nv4500 transmission from a cummins. engine mods will be new injectors, cam, better turbo (eventually), solid bumpers, probably 3" lift with the biggest tires i can fit under it on 16's and upgraded axle components
Sorta like what I'm doing to my 70 chevy 6bt 12 or 24 valve maybe a common rail, 30 frame, Dana 60 front, full float 14 bolt rear, nv4500v, 8-10in of lift 37s military tires at first then 40s, victory red, gonna be sweet!
im thinking red but idk what shade. and id go 24 valve. i hear they got more oomph. id like to put dual black hood scoops and a roll cage in the bed. with the mods i wanna do i think the 4bt will pump +/- 200hp and 400 ft/lbs.
Age : 25 Join date : 2013-04-05 Points : 4963 Posts : 661 Location : New Smyrna Beach,Fl
