| I NEED HELP NOW! | |
13mudman13 Member
Age : 26 Join date : 2012-09-20 Points : 4541 Posts : 67 Location : Wirt County, West BygodVirginia
| Subject: I NEED HELP NOW! September 22nd 2013, 12:23 pm | |
| I have a 14hp Briggs that I'm putting on my big Murray. The two engine pulleys are held on by a key way. (No bolts or anything) it won't budge! How do I get it off? I'm on a hurry to get my Murray mudder going again! | |
| | | cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5021 Posts : 232 Location : fairhope Al.
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 12:41 pm | |
| Your gonna need a puller most likely. Go to your local harbor fright and get the 3 jaw puller. If money is not a issue get one from a local place though. | |
| | | 13mudman13 Member
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 12:53 pm | |
| I don't have any money, is their another way I could do it | |
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 12:58 pm | |
| A puller and try penitent spray. Maybe a few taps of a hammer too, wiggle back and fourth. | |
| | | 13mudman13 Member
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 1:18 pm | |
| Are the engine pulleys aluminum? If not I can just cut them off and re weld them | |
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 1:38 pm | |
| They are steel but I doubt you can perfectly weld it back together if you cut it 50/50. | |
| | | Thecrazyoldcraftman Member
Age : 27 Join date : 2013-05-27 Points : 4283 Posts : 79 Location : San Antonio
| Subject: Re: I NEED HELP NOW! September 22nd 2013, 3:16 pm | |
| Get a propane torch and heat it up real hot then get a hammer and tap the shaft as you pull the pulley. | |
| Who is online? | In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests
