| "THE BRUSHEATER" tractor build | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5374 Posts : 1135 Location : Southern Florida
| Subject: "THE BRUSHEATER" tractor build September 15th 2013, 2:35 pm | |
| So for alittle while I've had this old weedeater tractor and I just got the tins for it so ima gonna make a bush wacker with it use it to beat up and go through brush make trails etc. it's gonna get a 12.5 flathead and 5 SPd tranny. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5720 Posts : 1402 Location : Central PA
| Subject: Re: "THE BRUSHEATER" tractor build September 15th 2013, 8:26 pm | |
| Lol yeah I'm gonna swap the drive train from mower to right plus tires then bumper, and that's about it lol also has a 4 in rear pulley and may put a 7 in front | |
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: "THE BRUSHEATER" tractor build September 15th 2013, 9:08 pm | |
| i see the Canadian craftsman hood found its way to your lt1000 right there. you have a lot of projects! | |
| Subject: Re: "THE BRUSHEATER" tractor build September 16th 2013, 8:00 pm | |
| IVE CREATED A BEAST! So it finally stopped raining and I got my self outside and got the engine and the axle in I still have to make custom shift linkage so I can keep the original shifter and I need to set up a belt and needs to be leveld out more. Ill post pics later my Internet is really slow right now | |
| Subject: Re: "THE BRUSHEATER" tractor build September 17th 2013, 4:27 pm | |
| The higher front end might help in your trail blazing adventures.
Something I want to do for mine is cut out a bunch of triangles, put a bevel on 2 sides and bolt them together. If they are beveled right, they will either cut, or rip, or simply pull out weeds and small trees. I also want to do that for my lawn chief grass cutter,as there are time I go over something and it pops back up.
Maybe you can do something similar to help in you trail blazing adventures. Though, I wouldnt recommend them sticking out front if your machine goes very fast... ofcourse, it could always be under the thing.... | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5024 Posts : 232 Location : fairhope Al.
| Subject: Re: "THE BRUSHEATER" tractor build September 17th 2013, 5:36 pm | |
| I saw on a truck forum the other day that a higher front end does help getting through mud, and some people run trucks like that. I guess it would be the same about lawn mowers. It looks just like an old craftsmen, AYP most have made it for them to | |
Age : 23 Join date : 2013-04-08 Points : 5212 Posts : 913 Location : Central Pa
| Subject: Re: "THE BRUSHEATER" tractor build September 20th 2013, 10:07 pm | |
| I think you should leave the front end how it is, like others said it may help going through brush, but if you leave it like that to go through brush you will get twiggs and crap stuck up in the underside of your tractor. *cough*cough*SKIDPLATE*cough*cough* | |
| Subject: Re: "THE BRUSHEATER" tractor build November 12th 2013, 9:56 am | |
| I may revive the tractor soon I got a tensioner but still no plastic thing for the fuel line and ideas on how to remove the little stub and put in a full metal nipple? | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
| Subject: "THE BRUSHEATER" tractor build November 14th 2013, 1:53 pm | |
| My cousin has one of those but with a different hood, I may get him started on this hobby someday. | |
