 Where to put batterie
5 posters
Kody6
Kody6
Where to put batterie Empty
PostSubject: Where to put batterie   Where to put batterie Icon_minitimeJuly 26th 2013, 2:48 pm
I have a lawn flite mtd and I got a new batterie that is bigger then the old one and the old batterie was in front of me close to the double pulley system and now it's to big any ideas of where else to put it
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeJuly 26th 2013, 3:01 pm
considerations I would take into account
1. protection from damage
2. ease of access for jump starting
3. ease of removal / install
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeJuly 27th 2013, 8:13 pm
Make a mount somewhere. MTD for some stupid reason decided to use Powersport batteries instead of L&G batteries.
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeJuly 27th 2013, 8:17 pm
When faced with a situation like that, I try to find a plastic box that can work as a battery tray/box and bolt it to the back of the mower and run new cables. If the location is impractical I adapt the same method to move it up closer to the engine somewhere. When it works it works very well and keeps the battery protected.
Kody6
Kody6
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeJuly 27th 2013, 8:19 pm
K thanks for the idea
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeJuly 31st 2013, 8:20 pm
Both of my Mtds have regular tractor batteries..
Ive only seen 1 with the motorcycle battery..
Just mount it under the seat cut it out and make a tray..
FOSWMT
FOSWMT
PostSubject: Re: Where to put batterie   Where to put batterie Icon_minitimeSeptember 25th 2013, 4:58 pm
Made a larger bracket from the existing bracket on my Gazelle . This was made out of Angle Iron welded on to existing bracketry. I can now fit a full size battery in the original position
Where to put batterie 3379_610
http://www.friendsofspeckledwood.org.uk
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: General Electrical Topics-
