 No more biycicle brake gas pedal
RCG
7 posters
RCG
RCG
2016 Build-Off Finalist
No more biycicle brake gas pedal  Empty
PostSubject: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 7:41 am
http://www.Mudmower.com
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 8:39 am
Nice pedal! Couple thoughts to share... For safety's sake and my own peace of mind, I would put a return spring on the carb. Flexible cables don't push very well at all, and a bit of debris in the casing or on the engine's throttle plate, and it will stick. Better to just add a spring, IMO. the other thing I see is that the pedal offers a lot of cable travel (a good thing) but the way you've got it set up is that the pedal sits very high and does not move much. I think I would set it to sit lower in the off-throttle state. Thoughts?
-You'll have to let us know if the epoxy holds up to the abuse!
RCG
RCG
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 8:59 am
Well said Doc
I agree on the spring on the carb and as of 2 hours after this video was made. I put one on as the return on the carb side was to slow.
The pedal throw area is massively adjustable on this thing and do to is simplicity in design
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 9:53 am
All of ours have a spring directly to the throttle at the carb, just in case the cable breaks.  Which does happen, not real common.
Also have it a stop on the gas pedal so when you floor it, it doesn't stretch the cable.
Cool gas pedal.  Is the cable on the floor of it?  Looks like it could get packed full of mud, maybe put a cover on it?
RCG
RCG
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 10:00 am
all very good points
I had thought of the over draw on the cable and made a custom stopper for the pedal.
As far as the mud getting in I do think that will happen but I think a cover would actually make the situation worse and pack it in more.
crazykid1994
crazykid1994
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 1:37 pm
that looks like the pedal i just ordered :p nice. i need to pulley swap my rear pulley larger. 30mph is to fast for me in 5th but maybe after i get my bumper and gas pedal itll b better
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 22nd 2013, 5:29 pm
My thoughts exactly doc. If you do what he said it will be usable, cause that throw (gearing) looks unusable.
RCG
RCG
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 23rd 2013, 11:06 am
After installing a return spring on the carb side it has become far more responsive.  I will be buying a secound pedal  this winter to play with mod ideas to make it more variable
crazykid1994
crazykid1994
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 23rd 2013, 10:12 pm
i wonder if there is a way to make it nore sensetive. a bigger range of motion at the pedal. i think that would b interesting to play with
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 23rd 2013, 10:15 pm
Looks kinda awkward to use. Like it sits too vertical, especially since you barely move it.
PostSubject: Re: No more biycicle brake gas pedal    No more biycicle brake gas pedal  Icon_minitimeJune 23rd 2013, 11:43 pm
Seems like the throw of the petal and action is to rapid, crawling looks hard. I did my bycical handle gas because it was free and works but your petal makes mine looks like crap, it really looks cool.
» M-99 1999 murray wide body
» how to make a brake pedal out of old deck parts
» Trans Axle Input Shaft Brake (Pinion Brake)
» Brake idea, using existing brake.
» how do i make a gas pedal ?
All-Terrain Lawn Tractor Forum :: General Tractor Talk + Pictures/ Videos :: Pics and Videos-
