 Tubed cage for mower?
Chopperhed
motorizedeverything
Murray modder
dylansrockinrigs
14 posters
Tubed cage for mower? - Page 2 Empty
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 7:50 pm
[img]Tubed cage for mower? - Page 2 Image_28[/img]
Cage design. hard to understand yes but I outlined the tubing in pen and penciled in the motor and chassis
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 7:54 pm
Yeah I know you want that, and that'd be awesome to see. So why all others talking about a roll cage???? It's not the same! bounce
Edit: And that's a kick ass drawing lol
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 8:06 pm
I can see were your coming from. I guess a roll cage is for something that already, or had a pre-existing cab and your just weldin bars in it
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 8:09 pm
I did think about getting a craftsman frame or something, and getting a twin, and rear end from the junkyard. then I can swap parts from my shitty mtd. mtd gots no frame.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 8:20 pm
So there's a lot of welding and bending on such a frame, you up for it?
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 8:43 pm
The exocage is a really cool idea. Crawler stuff. front suspension at the very least. To hell with the seatbelt- get a harness.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 8:46 pm
I think ill use 1 1/2 tubing. and thunder, totally I just need those magnet things that hold metal pieces together
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 27th 2013, 9:11 pm
1 1/2in tubing will work it will work great for a roll cage.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 7:15 pm
[img]Tubed cage for mower? - Page 2 Image_31[/img]
Bigger and newer drawing. Re-did the design, still some things I don't like but for the most part it looks sick. I think im going for a craftsman lt1000 type frame, and a v twin, or opposed. anything that's 17hp and up in the junkyard ill take. ill see if the frame in the junkyard has a transaxle and what one. I want a 820, but ill have to do some research on what mowers that axle was in. The front end will be indestructible, and following stretches, or rainbows design as far as spindles.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 7:26 pm
Looks like a strong design.
Murray modder
Murray modder
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 8:09 pm
Remember, the triangle is the STRONGEST geometric shape.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 8:24 pm
Yeah it is strong.
And also gussets.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 8:32 pm
Instead of the hold front part coming off like all of the front tubing I think ill just make the tubes that go over the engine removable. like a hood made out of tubes. id just pull the motor up and out
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 9:09 pm
Good idea.
Chopperhed
Chopperhed
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 9:24 pm
You could remove 2/3ds of the tubing, Triangulate more, and save a lot of weight and money
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 9:45 pm
true true. I want it to look cool tho lol.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 9:55 pm
[img]Tubed cage for mower? - Page 2 Image_32[/img]
Heres my "insdestrictable" front end concept. uses the spindle ideas from stretches idea, im giving him full credit. I just raised the beam.
Chopperhed
Chopperhed
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 29th 2013, 10:04 pm
Nothing looks cooler than "well built" and sound cooler than hearing "he does good work"
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 6:49 am
Agreed! No need to have all that steel in there- it can still be insanely strong with much less weight.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 12:54 pm
Thats gonna be one strong frontend.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 1:31 pm
Where can I spend my credit, LOL?
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 3:29 pm
LOL funny guy
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 3:30 pm
so I get everyones point. im going to draw up a new design with more triangles and less mat'L.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeApril 30th 2013, 4:25 pm
Remember you have to build what you draw afterwards.
So you may want interlocking lines (pipes).
So easy base, start, is 4 pipes length wise. The rest should be for strength and support.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeMay 6th 2013, 6:26 pm
More ideas. someone wanted a back view (?) and the hood or removable engine cover was just a quick idea not nessisarly going to change
Tubed cage for mower? - Page 2 Image_47
More triangles.
[img]Tubed cage for mower? - Page 2 Image_48[/img]
I saw a gt1000 frame and 18.5 vtwin in the junkyard, that was the style frame I liked. don't think ill get it tho, might wait for something better.
PostSubject: Re: Tubed cage for mower?   Tubed cage for mower? - Page 2 Icon_minitimeMay 6th 2013, 6:35 pm
Yeah.
I like the design.
» Speed Mower Vs Race Mower?
» exo-cage/hood rack
» BUILDING THE MOWER - DAYS OF THUNDER RACE MOWER
» What kind of mower can be used as a racing mower?
