 Peerless 700 transmission questions
D.U.B.S.
D.U.B.S.
Peerless 700 transmission questions Empty
PostSubject: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 10th 2013, 2:18 pm
Hey guys, I want to get a peerless 700 transmission for my monster mower build. But as I look online, I see some with output sprockets, and some without. I also see some with spined output shafts. I guess you can get spined sprockets for them, right? and are there different model designs that I should be aware of? I want to have a pulley on the input shaft, and a sprocket on the output shaft. I want to use it to run my rear axle.
Thanks
PostSubject: Re: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 10th 2013, 3:48 pm
A splined shaft can always be modified to use a non-splined sprocket.
If it helps, theres a link to a .PDF of the Tecumseh Technicians handbook, and it covers the 700 series.
https://www.facebook.com/notes/all-terrain-lawn-tractor-forum/tecumseh-peerless-technicians-handbook/394122567351351
D.U.B.S.
D.U.B.S.
PostSubject: Re: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 11th 2013, 11:18 am
Ok, so I could put a keywayed sprocket on there? How would I convert it?
PostSubject: Re: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 11th 2013, 5:44 pm
Just flatten one side and then stick a bit of key stock in and use the retaining bolt on the pulley and youll be set.
Thats how I did it when I pulley swapped my FNR in anyway. Should work for you.
PostSubject: Re: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 12th 2013, 3:07 pm
There's many different 700's, do a read on ratio and buy the one needed is my 2 cent.
PostSubject: Re: Peerless 700 transmission questions   Peerless 700 transmission questions Icon_minitimeApril 12th 2013, 3:25 pm
Great idea! I have a built up 700 series that somehow lost it's sprocket ( I think thieves - people try stealing my goodies all the time around here) I was going to try an experiment with it and couldn't figure out how to get a non-splined sprocket onto it. Now I know Smile Thanks!
» Peerless transmission.
» peerless 739 transmission problems : advice needed
» Make your own transmission?
» ALL Peerless-Tecumesh Transmission/ Transaxle Technicians Handbook [.pdf]
» Low Speed Tractor w/ Peerless 820 + Automatic Transmission Fluid = ?
