 12 hp B&S help!!!
13mudman13
12 hp B&S help!!! Empty
PostSubject: 12 hp B&S help!!!   12 hp B&S help!!! Icon_minitimeApril 2nd 2013, 4:28 pm
For some reason every time I crank over my engine it won't start and a big line of gas comes out the muffler. Pls answer for me. Thanks
PostSubject: Re: 12 hp B&S help!!!   12 hp B&S help!!! Icon_minitimeApril 2nd 2013, 4:31 pm
Float is probably stuck, and the carb is dumping fuel into your engine unchecked. Shut off the fuel, pull the spark plug and change the oil.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Once that is done, take the bowl off the carb and clean it out really good.
Chaos Build
Haspin 2021 thread
gearheadmike
gearheadmike
PostSubject: Re: 12 hp B&S help!!!   12 hp B&S help!!! Icon_minitimeApril 2nd 2013, 5:56 pm
yea i had a needle vavle stick and a half gallon of gas ended up in the motor. take check needle valve new plug/oil and if i were you id put a fuel shut off on it and everytime when done riding shut it off.
BlackMountian88
BlackMountian88
PostSubject: Re: 12 hp B&S help!!!   12 hp B&S help!!! Icon_minitimeApril 12th 2013, 6:19 pm
Hah well they're exactly right. Also it could be a fuel pump but the small engines don't have them. Smile
12 hp B&S help!!!
