| Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) | |
+9noledroByrreK DICE464 MSteele323 Ford Boi Farmster Chunk dangeroustoys56 Webmaster Jamus 13 posters |
Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6186 Posts : 779 Location : Angus, Scotland
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5701 Posts : 332 Location : Here!
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5772 Posts : 511 Location : Southern WV
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 8th 2010, 3:59 pm | |
| Yeah it will be fairly similar to your rig FearlessFront. I'm trying to figure out the belt and pulleys now. I watched your overview vid many times trying to recreate the two idler/tensioner pulleys that you added. Did you make a bracket attached to the frame to mount them or are they attached to the sheetmetal body? I may have to bite the bullet and just buy a new shorter belt. A new belt isn;t a bad idea anyway, whatever length. | |
Farmster Member
Age : 29 Join date : 2010-08-06 Points : 5241 Posts : 46 Location : Frankfort,Indiana
Farmster Member
Webmaster Webmaster
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 10th 2010, 5:02 pm | |
| - Jamus wrote:
- Yeah it will be fairly similar to your rig FearlessFront. I'm trying to figure out the belt and pulleys now. I watched your overview vid many times trying to recreate the two idler/tensioner pulleys that you added. Did you make a bracket attached to the frame to mount them or are they attached to the sheetmetal body? I may have to bite the bullet and just buy a new shorter belt. A new belt isn;t a bad idea anyway, whatever length.
The adjusable one is hooked to the frame, the other one was connected to the sheet metal.... Not a good idea. I removed it a while back, but it didn't go as well through the water. Check out my newest vid because i changed it all around. It may give you some ideas? - Chunk wrote:
- Maybe with some paint or rubber coering to tone it down a little.
Yeah, they sell the rhino liner stuff in aerosol cans. Thats a really good idea! I have an old plastic school chair that I stole long ago...(I'm sure i had my reasons). I may coat it and put it on the craftsman. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 13th 2010, 11:06 pm | |
| I checked online first and they didn't have the 1-piece when I got to the store. That's when I remembered the weld together ones over in the tractor section. The collar and pulley were cheaper than the 1-piece that they didn't have anyway, haha. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 14th 2010, 11:17 am | |
| I've often wondered about outside the US and lawn mower parts. Seems like lawnmowers are the last SAE holdouts. Every car you buy in the US is assembled with metric hardware these days. Do you guys over the pond run into any English-metric problems on your mowers? I enjoy being able to use all SAE tools on something as the last few trucks I owned were a mix-n-match of SAE and metric. I'm also enyoying being able to pull motors with my bare hands and no hoist needed, haha. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 16th 2010, 10:24 pm | |
| Ran into all kinds of trouble this evening. First, the rims won't budge off the wards/mtd. I about destroyed my steering wheel puller trying. Moving on I tried to see how the 14hp opposed twin on the murray chassis. It's almost too wide for the hood, it's over 3" too tall, and the stock holes in the motor plate do not line up. Well the motor plate is no problem, drill some holes, simple. The width isn't much of a problem either, it does fit but it's snug. Before I start fabbing I am going to try the hood off my 97 murray, it's a little different design. If that doesn't work I'm left with not running a hood, or making a body lift of sorts. I could raise the hood mount and the sheetmetal that the steering shaft runs through about 3 1/2" without raising the center of gravity much. I was really hoping everything would just fit together properly though. One good thing is that it has plenty of room to mount the winch down on the frame under/behind the hood. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 31st 2010, 8:24 am | |
| yeah i had a hell of a time pulling the wheels from my 91 mild mod MTD - had to use 1/2 can of PB blaster, a large hammer and use a couple old sockets to get the things off - i bent the bolt in the puller just a lil bit tho.
To prevent further issues later on- i used a grinder and lightly ground the axles smoother and never seized the snarkies out of em- the wheels slipped on and off by hand, so i absolutely had to make sure the wheel bolts were tight.
Looks like murray didnt design those tractors to fit a opposed twin.... i used an old MTD hood on my murray.
You might want to make a clutch setup like Fearlessfront- i had mine set similar to yours and didnt work worth a crap. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 31st 2010, 11:14 am | |
| I considered Fearless's clutch setup but want to get this thing running asap. If it doesn't work I'll change it. I don't know what I'll do for the hood. Only reason it even concerns me is that if I raise it, I also need to raise the dash, which probably needs to be decided before mounting the gas tank, and so on. | |
Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5434 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) August 31st 2010, 1:18 pm | |
| You can always out out the top of your hood to fit around the motor and either leave it open or fiberglass a big scoop on there or something. Or mount a scoop on the shroud that protrudes through the hood like a 'shaker' lol. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) September 1st 2010, 8:29 am | |
| Shame the hood doesn't fit round that motor. Maybe if the engine was moutned further forward, but then you;d loose your winch space. Think you might just have to cut it As for the chassis, might be a good idea to get some nice thick bed liner or something and coat it while you have everything off to stop it rusting anymore. Definatly getting closer now though! | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) September 1st 2010, 10:56 am | |
| I'll definitely strip all that rust off and paint the frame. Most of it is due to water getting in through the hole in the body for the battery. Also to blame for the pulley not coming off of the transaxle. I might try and put the wards/mtd hood on it, that would look strange. | |
| Subject: Re: Montgomery Wards(MTD) trail tractor(Now Murray Widebody LT) September 1st 2010, 6:42 pm | |
| Mine did at first, but i actually liked it after a while - the original murray hood ( had the plastic grille ) was all smashed- even epoxying it together didnt help. Heres a pic of the old murray with the MTD hood n twin: I had to cut the dash back a little bit to make it fit - also make a hood lock out of a bolt - so it didnt flop open on me. I also had a spare bolens hood lying around- heres what that looked like: Heres what it originally looked like- you can see all the cracks in the grille: | |
