| Need help BY TOMORROW please! | |
+2Ariens YT11 BlackMountian88 6 posters |
BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4896 Posts : 399 Location : NH
| Subject: Need help BY TOMORROW please! March 28th 2013, 3:47 pm | |
| Hey everyone, I've got a late 80's B&S 12hp motor, and it will randomly cut out at times. It suddenly starts to stall out, lacks power, surges and dies. I had no exhaust on this engine up until this week, which it now has a straight pipe that curves out and upwards, I don't know if that might be a problem. The carb leaks slightly but other than that it's fine. I don't think its electrical. I really wanna get this going for tomorrow's 50+ degree weather!
Thanks! I can post pics if needed. | |
Age : 27 Join date : 2012-10-31 Points : 5167 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Need help BY TOMORROW please! March 28th 2013, 5:13 pm | |
| have you tried Seafoam? Half in the fuel and half down the carb? note: when putting it in the fuel only have 1/4 of a tank so it is a rich mix of fuel and seafoam.
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4460 Posts : 121 Location : PA
| Subject: Re: Need help BY TOMORROW please! March 28th 2013, 8:57 pm | |
| yea try to clean the carb that sounds like the problem, by any possible chance, does it have good compression? | |
ibdalovely1 Member
Age : 45 Join date : 2012-12-27 Points : 4470 Posts : 92 Location : dayton ohio
| Subject: Re: Need help BY TOMORROW please! March 29th 2013, 1:42 am | |
| my snapper had a bad coil it would run for a while and just loose power and die if i let it set for a while it would start again | |
| Subject: Re: Need help BY TOMORROW please! March 29th 2013, 9:13 am | |
| I haven't checked the compression yet, I usually just put my thumb over the spark plug hole and turn it over.
The coil is from a 18hp twin, but I can put the original back on. | |
| Subject: Re: Need help BY TOMORROW please! March 29th 2013, 1:37 pm | |
| - BlackMountian88 wrote:
- I haven't checked the compression yet, I usually just put my thumb over the spark plug hole and turn it over.
The coil is from a 18hp twin, but I can put the original back on. just turn the motor over by your hand and does it have comression or just turn over no problem? Or do you have a compression tester? Just a thought. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7785 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Need help BY TOMORROW please! March 29th 2013, 4:14 pm | |
| I would check you electrical for frayed or exposed wires. Gap your coils, etc. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Need help BY TOMORROW please! March 29th 2013, 4:17 pm | |
| Ya I have been working on that recently. It's just one wore to the kill switch, then to ground and the wire is brand new. | |
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4597 Posts : 327 Location : Rindge, NH
| Subject: Re: Need help BY TOMORROW please! March 30th 2013, 8:04 am | |
| I have a manual choke right now (no cable, I just reach and pul l the lever) and I did hook a spring up to that. If it doesn't start this morning I'm going to change the coil, and check the fuel filter. | |
