 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12
jsisti845
Angchor
Moose
DirtyD
T-Dub13
Rkeefe99
crafsmankiller
donfordguy
camomanusa
Jedi
TroyBilt Pony
GenevaCustoms
FOSWMT
crazykid1994
matt-man
(509)Mowers
dylansrockinrigs
Marines2621
motorizedeverything
goesman
WellThatsSurprising
MowBandit
Ddwannabe
Kel
greener179
Murray modder
mudmonkey06
xxXMowerdudeXxx
Chopperhed
gearheadmike
49 posters
Go to page : Previous  1, 2, 3, 4 ... 13 ... 23  Next
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Empty
PostSubject: LOL?   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 4:17 pm
LOL?
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Ab755d52-994f-48c6-9040-ce7c212f28a0_zpsbd3f44dc
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 4:22 pm
Got two new gauges today, Exhaust temp sensor, and an Air / Fuel mix.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 90BD4D32-DDAD-4E07-81DD-9F1995121403-39245-00002AE9A07BFB8A_zps855a1ebc
And man!! My first time ordering belts online went bad lol
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 B7D7EA11-D983-4D8F-AFE2-E6AE6477B1B4-36300-00002A067A815594_zpse12d5b5d
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 8:25 pm
So after thinking a lot what to choose for a drive train for my mower. - I've settled on a CVTech Series 80 Clutch, then via a Jack shaft to a chain drive(If im not flipping the 820-037).
- So if i did the calculations correctly it should do 92MPH in 5th Gear. (Left). Right is for a more Torque/ mid range gearing set at 7500rpm (Right). All with 16" Wheels.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CALC_SPEED_MPH_zps3d97c186
820-037 Gearing:
For the technically-minded*, the Forward-shift gear ratios are: 1st) 4.55:1; 2nd) 1.50:1; 3rd) 1:00:1; 4th) 0.79:1; and 5th) 0.61:1.
Input pinion ratio is 2.54:1, final-drive/differential ratio is 8.02:1, and Reverse is 2.00:1. Other gear ratios are available for this trans axle.
Gearshift/ RPM.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CALC_SPEED_zpsd22c79f8
CVTech
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CVTech_DIA_zpsd6cab215
Pulley size from Engine to Jack Shaft (CVTech)
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CVTech_zps6b674f4e
Then Jack shaft via Sprockets/ Chain to 5/8" Input shaft on the 820 Peerless.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CVTech_DIA_3_8inchsprocket_zps7a2d9f5a
And then same but with a "milder" gearing Torque/ mid range.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 CVTech_DIA_2_zps8f999394
Murray modder
Murray modder
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 8:35 pm
hope you plan on running this thing for strictly for drag racing. Mower fames are a little narrow when it comes to stability. Mine sits 46 in long by 32 in wide, 33 in tall, and on a 90 degree corner going 20, I feel like I'm going to tip. While Im probably just over boarding this thing, I really hope you plan on adding some sort of wind-shield. Running 90-some miles and hour and hitting a horsefly or something is going to HURT
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 8:43 pm
Thanks for your concern, but this will be custom built, and not limited by any Width restrictions. the only limit is my head. I figured this would be 46-48" wide in the front, not so wide in the back. - The 820-037 Peerless is 30" wide total. With 9" wide rims should make it, Well 30+9+9- offset and bolt on. aprox: 45" wide in the rear. And it will be 2-5" of ground clearance. and no windshield. Shocked
Helmet and old school racing goggles Exclamation What a Face
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 8:53 pm
Just caught up on youtube videos and this thread, this is shweeet. The 4 link and custom frame are awesome. the pictures are very detailed and I cant wait till its done!! I wish I had a shop like yours hahaha
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 8:55 pm
Thunderdivine wrote:
Front, 4-link design. Already changed this, kingpin (built in camber) is only 10 degrees here (mixed it up with caster :p ) will increase to 14 degrees.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Susp_design_zps51321554
I would like to do something like this for my mud mower.
Looks good.
Murray modder
Murray modder
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:00 pm
Mine sits about 4 in off the ground, while 90-some MPH sound cool, it isn't to safe and something so small, even with good caster/camber/kingpin set. But if your extremely positive this is how you want it, down force is critical. And I honestly think your setting a record speed with it as well...Last thing I'd like to say is, Good luck.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:05 pm
I'm not even sure that it will be my actual speed tho, so I would'nt take it to serious Smile
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:06 pm
Thanks, I'm subbed to you on YT. all I see now is a boat. (Nice btw). and the saw is at work pirat
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:11 pm
Yeah you dont want to go to fast it could be unstabe.
I think the worlds fastest lawn mower is 80+ MPH if you wanted to beat the record.
mudmonkey06
mudmonkey06
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:34 pm
ya and if i remember correctly nitro circus di it. and if you want to go tht fast i am seriously suggesting some downforce
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:35 pm
Yeah.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 9:53 pm
Who?
And idc about no record.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 10:01 pm
Youd care if you broke it! ill look it up:
https://www.youtube.com/watch?v=irjVzebbyQ8 96mph set in 2010
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 10:07 pm
the requirements are that it has to have a max hp of 20 hp and has to have a lawnmower rear end in it if anyone was wondering.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 5th 2013, 10:21 pm
Yeah i thought you could use any motor thats was for a lawn mower.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 9:54 am
CVTech Sys Ordered, pirat
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Capture_04112013_111114_zps3220e876
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 11:22 am
Cool.
Is that for the cluch?
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 1:19 pm
truckin42 wrote:
Cool.
Yea, this is rated for 20HP.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 2:30 pm
88 MPH to be exact
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 2:33 pm
88 MPH to be exact
96mph but never mind that record now, we don't have any salt lakes Smile
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 11th 2013, 3:04 pm
Yeah we dont have any salt lakes here ethier.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 12th 2013, 10:16 am
Can I quote myself bounce
Well sad news, the only page where I found this exact CVTech, they are: "Out of Stock".
And he wanted to sell me the weaker Comet / Clone model 40. By that I reckon they won't have them In stock anytime soon either. Sad
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 12th 2013, 10:53 am
Oh so you wont be getting it for a while?
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 3 Icon_minitimeApril 12th 2013, 11:52 am
I guess.
Page 3 of 23Go to page : Previous  1, 2, 3, 4 ... 13 ... 23  Next
» racing mower project
» Murray Select Racing Mower Project
» Stallion Racing Mower (Project Yeah Buddy)
» craftsman racing mower
» Mod XR Racing Mower (Craftsman)
