| "The Illuminator" My Rally | |
+19LAWN MOWER MUDDER MowBandit Jerbear0612 TheRainbowBoxer mudmonkey06 Doc Sprocket redlinemotorsportts Ariens YT11 motorizedeverything greener179 Ddwannabe Thunderdivine richie thomas truckin42 dangeroustoys56 Chopperhed Tractor Man Jeff Doug xxXMowerdudeXxx 23 posters | |
xxXMowerdudeXxx Established Member
| | | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
| | | | mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4596 Posts : 327 Location : Rindge, NH
| Subject: Re: "The Illuminator" My Rally June 6th 2013, 8:33 pm | |
| nice lol.
i find it ironic that you said in a previous post you dont want to lock it because it will ruin the tires . then i go down a few more posts and see this lol
i wish mine did burn outs | |
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: "The Illuminator" My Rally June 6th 2013, 8:37 pm | |
| - mudmonkey06 wrote:
- nice lol.
i wish mine did burn outs We're in the same boat. just need a motorcycle engine... | |
| Subject: Re: "The Illuminator" My Rally June 6th 2013, 9:20 pm | |
- nice lol.
i wish mine did burn outs u do got a point there, LOL | |
| | | | Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6545 Posts : 2101 Location : Norway, Europe
| | | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5505 Posts : 1070
| Subject: Re: "The Illuminator" My Rally June 6th 2013, 10:45 pm | |
| - truckin42 wrote:
- Cool.
Did your mower really do that? yes, the little ones, not the giant powerstroke one my buddies did | |
| Subject: Re: "The Illuminator" My Rally June 6th 2013, 11:45 pm | |
| - truckin42 wrote:
- Oh ok i thought your mower did the big ones.
NOOO!!1, i wish, XD those are a truck marks my buddy did, lol | |
| Subject: Re: "The Illuminator" My Rally June 7th 2013, 9:11 am | |
| - xxXMowerdudeXxx wrote:
NOOO!!1, i wish, XD those are a truck marks my buddy did, lol Lol i figured the big ones where automotive. | |
| Subject: Re: "The Illuminator" My Rally June 17th 2013, 6:00 pm | |
| well, after seeing rainbows vids about haspin, the racers getting a rebuild, lol, going to be getting a 18 hp v twin, im going to strip it down, beef up the frame, beef up the tie rods, reinforce the frame, better clutch set up, locked rear end, try to find ags for it, cheap, hopefully. thern i gotta reinforce the part where i sit its almost completely cracked off, replace the stock bolt screw things with real bolts, they keep coming out. also with the tranny im going to take out most of the gear oil and put in some really expensive good grease, a few guys on here use and i can do high speeds with it. then make a foot brake, the hand ones not cutting it, lol, redo wiring sort of, just pull seat kill switch out of the circuit, and a few things i cant use now do to the hood being destroyed, lol. make a battery retainer to hold it in place, (yes i still haven't done one yet, lol) and im sure there more im going to do, just for got to post it, lol, but this will keep me busy, lol | |
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| | | | Jerbear0612 Member
Age : 28 Join date : 2013-04-23 Points : 4345 Posts : 89 Location : Salem ct
| Subject: Re: "The Illuminator" My Rally June 18th 2013, 8:55 am | |
| Sounds like a good plan. I had a 14hp vtwin awhile back on a craftsman and man that thing was sweet lol. | |
| Subject: Re: "The Illuminator" My Rally July 14th 2013, 7:04 pm | |
| the heart transplant is almost done!!! i had this given to me today by a friend, told has issues. was told it was carb, but upon checking spark, only one side has spark, sooooo, she needs a new pacemaker(coil). i also changed the oil. also the top pieces for the carb are missing to hold the air cleaner together, i need those, or just make my own, lol. and i do have the rest of the shrouds so don't worry, lol. and if anyone wants to guess the hp, go for it i cant find it, heres the numbers 402707 0140-01 code: 82090712. and if anyone has a coil, that will work, let me know. and i cant wait tio get it running and hope it was just coil and oil, and straight pipe it | |
| | | Guest Guest
| Subject: Re: "The Illuminator" My Rally July 14th 2013, 8:20 pm | |
| go get a quart .5 of elbow grease, and some muffler fluid and exhaust bearings... that starter will work fine |
| Subject: Re: "The Illuminator" My Rally July 14th 2013, 8:27 pm | |
| awesome md. Dual sidepipes? Hahaha, now you have enough torque to gear her higher. there should be a vent tube that goes to the airbox too. Like like a 16.5 or 18 oppy, my friends 16.5 opposed looks exactly the same minus a car fuel filter lol. | |
| Subject: Re: "The Illuminator" My Rally July 14th 2013, 9:39 pm | |
| gotta get r running first, it may burn oil idk, when i took out the spark plugs there was alot of black stuff, could be from sitting on its side, idk, but it didnt have much oil when i drained it, but then the drain pipe was bent and had a crack, so it could have run out. i hope all it needs is plugs oil, coil, and fuel line, or just plugs, lol, im gonna work on it some more tommarow | |
| | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4751 Posts : 477 Location : Haddock,Georgia
| Subject: Re: "The Illuminator" My Rally July 15th 2013, 12:07 am | |
| thats a 16hp 40CI block best block you could get for modding lol easy to turn that mofo into a stroker | |
| | | | LAWN MOWER MUDDER Established Member
Age : 23 Join date : 2013-04-08 Points : 5211 Posts : 913 Location : Central Pa
| Subject: Re: "The Illuminator" My Rally July 15th 2013, 5:52 pm | |
| - LAWN MOWER MUDDER wrote:
- Nice does the hood still fit??
He destroyed it when it fell into the creek. | |
| Subject: Re: "The Illuminator" My Rally July 15th 2013, 6:13 pm | |
| The hood would still fit, the frame was made to hold it, had all the holes pre drilled, and like red said its destroyed, I may try to fix it if I get really bored, or just find one like it | |
| | | | Sponsored content
