| "The Illuminator" My Rally | |
+19LAWN MOWER MUDDER MowBandit Jerbear0612 TheRainbowBoxer mudmonkey06 Doc Sprocket redlinemotorsportts Ariens YT11 motorizedeverything greener179 Ddwannabe Thunderdivine richie thomas truckin42 dangeroustoys56 Chopperhed Tractor Man Jeff Doug xxXMowerdudeXxx 23 posters |
xxXMowerdudeXxx Established Member
| Subject: "The Illuminator" My Rally February 26th 2013, 2:19 pm | |
Last edited by xxXMowerdudeXxx on July 26th 2013, 3:18 pm; edited 3 times in total | |
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 6:16 pm | |
| i need help coming up with a design for the bumper
Last edited by xxXMowerdudeXxx on February 27th 2013, 6:20 pm; edited 1 time in total | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 6:19 pm | |
| - xxXMowerdudeXxx wrote:
- i need help coming up with a design for the bumper the links above are pics
I fixed you up. All you needed were the image tags. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 6:21 pm | |
I fixed you up. All you needed were the image tags. Thanks | |
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 6:30 pm | |
Last edited by xxXMowerdudeXxx on February 27th 2013, 6:31 pm; edited 1 time in total (Reason for editing : i messed up lol) | |
Doug Site Owner
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 6:53 pm | |
| Does your hood open toward the front? Will make having a bumper difficult unless you change how the hood oppens or make the bumper a quick disconnect. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: "The Illuminator" My Rally February 27th 2013, 7:07 pm | |
- Does your hood open toward the front? Will make having a bumper difficult unless you change how the hood oppens or make the bumper a quick disconnect.
yeah it does, i think i will have it on like a pivot pull a pin and it drops, or the bumper leans forward | |
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5015 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: "The Illuminator" My Rally February 28th 2013, 10:29 am | |
| That suckers fast. I put hinges on the top of my dash to make the hood open like a car hood. | |
| Subject: Re: "The Illuminator" My Rally February 28th 2013, 3:27 pm | |
| - Tractor Man Jeff wrote:
- That suckers fast. I put hinges on the top of my dash to make the hood open like a car hood.
My hoods cracked on the top though, it fell and its plastic | |
Doug Site Owner
| Subject: Re: "The Illuminator" My Rally March 1st 2013, 10:28 pm | |
My hoods cracked on the top though, it fell and its plastic Cracked how? You might be able to get some small, thin flat stock (like 1/2" wide stuff, ive used some for my one paintball gun handgaurd) and some pop rivets/ small hardware and reinforce the crack so you could use hinges. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: "The Illuminator" My Rally March 1st 2013, 10:36 pm | |
My hoods cracked on the top though, it fell and its plastic Cracked how? You might be able to get some small, thin flat stock (like 1/2" wide stuff, ive used some for my one paintball gun handgaurd) and some pop rivets/ small hardware and reinforce the crack so you could use hinges. i think i'm gonna try some of that stuff my buddy neil used on his bike when it got layed over, its fiber glass body repair and you put some like steel mesh on it, but my hoods not fiberglass thought lol, i also put on ff's pull start today | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: "The Illuminator" My Rally March 1st 2013, 10:55 pm | |
My hoods cracked on the top though, it fell and its plastic What kind of plastic? First question when dealing with synthetic materials. Usually plastic parts will have a small stamp identifying the material. Its usually a small spot on the backside. There are various ways to fix plastic parts. It all depends on the actual plastic being repaired. Fiberglass parts can be repaired with standard polyester resin and fiberglass cloth. ABS parts need certain solvent to ensure adhesion. PVC has the same problem. Thermosetting plastics can be welded. The point is. use the proper material and a little work, and plastic can be repiared to look new. | |
Doug Site Owner
| Subject: Re: "The Illuminator" My Rally March 1st 2013, 10:58 pm | |
A bit of rough sandpaper and some plastic epoxy would probably work great too. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: "The Illuminator" My Rally March 4th 2013, 2:30 pm | |
A bit of rough sandpaper and some plastic epoxy would probably work great too. I'll do that then | |
| Subject: Re: "The Illuminator" My Rally March 4th 2013, 2:34 pm | |
| I had to redo my clutch linkage, was to short and now it works better. I also found out that it can sort of pop whealys, lol, also it can do nice spins if there is some dirt on the road. | |
Age : 54 Join date : 2010-02-10 Points : 7078 Posts : 1726 Location : Florida, USA
| Subject: Re: "The Illuminator" My Rally March 6th 2013, 7:29 pm | |
| Plastic epoxy isnt the greatest stuff - i used some of that to fix the grille on my murray ( cleaned and prepped it- even put some reinforcing plastic bits under it) - ended up cracking again a short time later - i shouldve drilled holes in the grille to lock it all together.
| Subject: Re: "The Illuminator" My Rally March 8th 2013, 9:52 pm | |
| LOL! so am I. Hey is that thing direct steering? If so, could ya post some pics of it? I'd like to see how ya did it. | |
| Subject: Re: "The Illuminator" My Rally March 8th 2013, 10:22 pm | |
- LOL! so am I. Hey is that thing direct steering? If so, could ya post some pics of it? I'd like to see how ya did it.
yeah it is, ill take some pics tomorrow for you. its probably not the best one out there but it works for what i do, its still got a little play which is fine when your only doing 30. if i were to buy some of those got kart ball joint things it would be golden. i know how to make it better but im lazy, lol | |
Doug Site Owner
| Subject: Re: "The Illuminator" My Rally March 9th 2013, 9:43 pm | |
| Thats not too bad, as long as your ball joints dont wear out you should be fine. When my now parts Snapper was still used to mow with, the front tie rod had ball joints which wore out and the entire tie rod fell off! Not saying that will happen but still, they arent made like car ball joints. Heim ends or whatever would be the best though. I plan on upgrading to them ASAP but they are expensive as all hell. Heres a link to a full set though if you need it. http://www.ebay.com/itm/200626992221Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
