| Oil cooler prototype | |
+7Murray modder TheRainbowBoxer crafsmankiller Thunderdivine W1ldyOvvnZ Chopperhed WellThatsSurprising 11 posters |
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5007 Posts : 407 Location : East Bethel, MN
| Subject: Oil cooler prototype February 25th 2013, 10:39 pm | |
| This is just another project with no purpose but to waste time. What I plan to do is deepen the oil pan on a B&S 10HP because I can. No real reason besides that. And after that I will install an external pump/filter that picks up from the bottom of the pan, runs it through a cooler and returns it maybe to the top of the crankcase to help with lubrication. Again, this has no real reason except to waste time and maybe turbo. Did I say turbo? You didn't hear that... Now for the guinea pig tractor: If there is one thing I try and do with my projects, It's keep them suprising! | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Oil cooler prototype February 25th 2013, 10:42 pm | |
| THIS is the kind of stuff I want to see. Imagine what you could do with a full pressure system.
These little motors could last forever.
Mind you, they last nearly forever with a splash system too.
Although I still want to see it. | |
| Subject: Re: Oil cooler prototype February 25th 2013, 10:51 pm | |
| - Chopperhed wrote:
- THIS is the kind of stuff I want to see.
Although I still want to see it. It might be a while, I can steal an oil cooler out of the next bike I part out, oil filter mount from extra parts for my Fiero.... Still in the planning stages here but any future project ideas for this motor are welcome also. | |
| Subject: Re: Oil cooler prototype February 25th 2013, 11:13 pm | |
| Try to fit in a swappable filter as well.
Clean oil is better than pressurized oil all the time.
Cooler Cleaner oil will help these little beasties live long lives.
Air cooled engines, like liquid cooled engines, are not cooled by the air/coolant alone.
Oil temparature has a large effect on engine temparature, as does the temperature of the incoming air/fuel charge.
Colder air is denser, making more power with the right tuning.
Last edited by Chopperhed on February 26th 2013, 1:45 pm; edited 1 time in total | |
| Subject: Re: Oil cooler prototype February 25th 2013, 11:23 pm | |
| Yes of course it's a swappable filter. A Fiero is a car. The part I was talking about is a re-locator plate because SBC 350 motor oil filters won't fit against the engine cradle. Therefore, this. And yes, I understand basic engine tuning. | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5251 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Oil cooler prototype February 25th 2013, 11:52 pm | |
| cant wait to see this, ive been thinking of doing something like that to my Honda Clone motor just to be able to run a turbo but there isnt a small enough turbo that would spool up quick enough for it to be worth while putting on. | |
| Subject: Re: Oil cooler prototype February 26th 2013, 2:20 am | |
| Figured out the parts I shall be using! Pump: SHURflo On-Demand Diaphragm Pump — 1 GPM, 60 PSI, 12 Volt, Model# 8009-541-236 http://www.northerntool.com/shop/tools/product_357081_357081It says it's not meant to be run continuosly but I have a few modifications to make to allow it. The oil pickup filter is off of a GL1000 motorbike. The actual radiator bit is a aluminum 30" transmission cooler. Then the rest I either already have or have to custom make. Oh, that and a bunch of little fittings and hose. Will start modification of the crankcase soon. | |
| Subject: Re: Oil cooler prototype February 26th 2013, 1:31 pm | |
| Well, I would have really liked to do a electric pump so I could turn it on an off any time and have it cool the engine after a ride when it's shut off but I feel as if I have already spent too much on this project. It was 60 for the cooler, 10 for the pickup and the new and final pump, 36 dollars. I thank JunkStar for giving me the idea of a motor scooter oil pump.
Last edited by WellThatsSuprising on February 26th 2013, 2:00 pm; edited 2 times in total | |
Thunderdivine Veteran Member
| Subject: Re: Oil cooler prototype February 26th 2013, 1:44 pm | |
| Will be kewl to see you do this, to bad it's not an opposed twin | |
crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4893 Posts : 412 Location : livingston texas
| Subject: Re: Oil cooler prototype February 26th 2013, 3:33 pm | |
| some engines already have full pressure lube, i know twins do, and some large singles. my 20 Horse had full pressure lube. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: Oil cooler prototype February 26th 2013, 3:51 pm | |
| Some twins have full pressure lube, not all. I have an opposed 16.5HP B&S and it is splash lube. | |
| Subject: Re: Oil cooler prototype February 26th 2013, 4:49 pm | |
Although I still want to see it. It might be a while, I can steal an oil cooler out of the next bike I part out, oil filter mount from extra parts for my Fiero.... Still in the planning stages here but any future project ideas for this motor are welcome also. Have you considered the drop in oil level when the pump starts? | |
| Subject: Re: Oil cooler prototype February 26th 2013, 5:00 pm | |
Although I still want to see it. It might be a while, I can steal an oil cooler out of the next bike I part out, oil filter mount from extra parts for my Fiero.... Still in the planning stages here but any future project ideas for this motor are welcome also. Have you considered the drop in oil level when the pump starts? Yes, that's why I said i'm deepening the oil pan. | |
Murray modder Member
Join date : 2012-11-23 Points : 4801 Posts : 356 Location : Somewher in Va
| Subject: Re: Oil cooler prototype February 26th 2013, 7:06 pm | |
| Why not run a cooler like a refriderator has? Keep the oil nice and cool...But the weight... | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| Subject: Re: Oil cooler prototype February 26th 2013, 7:07 pm | |
| Sounds like a good idea. How do you plan on making the pan deeper. | |
| Subject: Re: Oil cooler prototype February 26th 2013, 7:41 pm | |
| - Murray modder wrote:
- Why not run a cooler like a refriderator has? Keep the oil nice and cool...But the weight...
I like the way this cooler looked. - truckin42 wrote:
- Sounds like a good idea.
How do you plan on making the pan deeper. Cutting a hole and welding a box. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
| Subject: Re: Oil cooler prototype February 26th 2013, 9:06 pm | |
| my 29 hp kawasaki has a oil cooler on it that is rather simple, if you want i can try to get a vid of it tomorrow or the next day, | |
avrappy New Member
Join date : 2012-12-26 Points : 4368 Posts : 16 Location : N. IDAHO
| Subject: Re: Oil cooler prototype February 27th 2013, 9:54 am | |
| I had a better idea. If you are going to run a pump and cooler, why not spend the time and plumb the inside and do a dry sump system. You would have to run two pumps and a external tank. I'm thinking of doing this on a 15.5 kohler ovh flat. | |
Age : 27 Join date : 2012-10-31 Points : 5164 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Oil cooler prototype February 27th 2013, 1:28 pm | |
| Now I have a question why can't you get a oil cooler from a Chevy,Ford or,Dodge and mount it on top of the motor above the flywheel for the cooling? It would be cheaper and easier to fix if something happens. | |
| Subject: Re: Oil cooler prototype February 27th 2013, 1:49 pm | |
| - avrappy wrote:
- I had a better idea. If you are going to run a pump and cooler, why not spend the time and plumb the inside and do a dry sump system. You would have to run two pumps and a external tank. I'm thinking of doing this on a 15.5 kohler ovh flat.
Too much work. Maybe in the future but right now this is just a side project. Most of my money/time is going into big cat. - Ariens YT11 wrote:
- Now I have a question why can't you get a oil cooler from a Chevy,Ford or,Dodge and mount it on top of the motor above the flywheel for the cooling? It would be cheaper and easier to fix if something happens.
Because I liked the way this cooler looked. Eventually I will expand and have one cooler on each side running down the frame rails. And this is just my guinea pig tractor for ideas, Not doing any off-roading with it. | |
| Subject: Re: Oil cooler prototype March 21st 2013, 5:29 pm | |
| Finally got the pump, a bit smaller then I was expecting but as long as it works. | |
| Subject: Re: Oil cooler prototype March 21st 2013, 6:46 pm | |
| Cool can't wait to see what it will looks like in the future. | |
