 ID this rear end please.
TheEquineFencer
ID this rear end please. Empty
PostSubject: ID this rear end please.   ID this rear end please. Icon_minitimeFebruary 24th 2013, 11:03 am
The Data tag I found on it says: 4360-54 under that it says 137369. What do I have? I want to use it for an AVT type build if it'll work OK. What might it have come from?
Chopperhed
Chopperhed
PostSubject: Re: ID this rear end please.   ID this rear end please. Icon_minitimeFebruary 24th 2013, 11:47 am
436054
DANA/FOOTE/SPICER TRANSMISION
PART 436054
REPLACED BY: 436089
6 speed linear shift transaxle
I can't comment on quality or strength for mower applications, but Dana differentials are supposed to be some of the best for trucks
TheEquineFencer
PostSubject: Re: ID this rear end please.   ID this rear end please. Icon_minitimeFebruary 24th 2013, 12:02 pm
I'm trying to figure out what I have laying around to work with. I have that one and then the other is a Foote/Dana 4360-122 6. Is there a tread some where on this site that list transaxles with part numbers? are there differant gears available for these? Is there and easy way to hook a keyed sprocket to the axle to run to another shaft for a jackshaft to overdrive the output? I'm afraid if I overdrive the input too fast it'll cook the guts from lack of luberication at highspeed. I plan install really tall drive tires on the build but I'm not really looking anything stuipid for speed. I just want to go a bit faster than stock.
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: ID this rear end please.   ID this rear end please. Icon_minitimeFebruary 24th 2013, 10:40 pm
I have a Dana 6 speed and it has taken quite a bit of abuse. Still isn't any bit noisier then it normally is.
» BKC's Craftsman Build
» LOCKED TRANSAXLE
» Finally Got Better Pics!!!!!!!
» A different way to lock the rear end.
» rear atv rack :D
