 Safety switches and what not!
5 posters
13mudman13
Safety switches and what not! Empty
PostSubject: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 6:09 pm
Do any of u guys know how to get the saftey switches off of a craftsman lt1000. Where of u get off the seat of will shut off and the thing on the dash when u move it up it will not turn on do any of u know how to shut them of for remove them. Explanations would be appreciated
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 6:14 pm
Look up FearlessFronts video tutorial on YouTube, it full explains how to rewire a mower to bypass all of it and how to clean up the wiring. Otherwise its a lot of splicing to bypass those switches as most of then have 4 contact points inside them.
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 6:35 pm
You could try unpluging the wiring harness on the motor and make your own wiring harness.
For a kill switch Run a wire from the swith to the black coil wire and then splice them together,and then run another wire from the switch and ground it.
For a push button start switch run a wire from the switch to the post on the solinod,an then run a another wire from the switch to a positve wire running to the solinod.
And it should all work.
13mudman13
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 11:11 pm
But I'm still using the stock ignition switch
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 11:17 pm
If you know the model of your tractor go to partstree.com and look up a wiring diagram. Then save it and post it on the thread and I think I can show you what needs to be spliced.
Otherwise its a bit complicated.
13mudman13
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 5th 2013, 11:23 pm
Ok I'll do it some time tomorrow. Thanks doug
CornishMorgan
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 6th 2013, 8:06 am
Haha removing the safety switches was the first thing i did to my tractor. I don't need those pointless things.
RCG
RCG
2016 Build-Off Finalist
PostSubject: Re: Safety switches and what not!   Safety switches and what not! Icon_minitimeFebruary 6th 2013, 11:15 am
My mud mower is an lt1000
Under seat switch Cut the thing off ground to chasie
Deck engagement lever remove it place the switch threw the hole where the lever was hold down to start the mower. There your done Un less you want to disable the clutch switch I like having mine it makes sure my 7 year old cant get it started with out my help.
http://www.Mudmower.com
» FIRE!-safety
» Battery Safety VERY IMPORTANT !!!!!!!!!
» How to remove all the safety features?
» A really good safety feature...
» Safety Ideas and Tips
