| Hydro Question/ problem | |
Jonny Briggs New Member
| Subject: Hydro Question/ problem January 25th 2013, 1:55 pm | |
| I have a Hydro Gear rcl120002 trani, when I spin the pulley nothing happens, ive spun it with a drill and nothing happens?
Any idea's, does it need to spin faster to turn the axle?
Jonny | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Hydro Question/ problem January 25th 2013, 1:56 pm | |
| Its a hydro, the pump needs to be spinning at engine speeds to generate the pressure to turn the wheels. It also has to be full of oil, in either forward or reverse, and spinning the right direction. There is no mechanical connection between the input shaft and differential. | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4936 Posts : 208 Location : Tennessee
| | | | dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4808 Posts : 141 Location : central Wisconsin
| Subject: Re: Hydro Question/ problem January 25th 2013, 2:29 pm | |
| The axles won't turn if it is not "in gear" if it is in neutral position oil just bypasses. | |
| | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5164 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Hydro Question/ problem January 25th 2013, 10:17 pm | |
| - AcreFarm wrote:
- ^^^ This
Most have a Minimum input RPM in the 1500-1800 range. My Newer 06 Poulan Has a 1:1 on it and it does fine. | |
| | | AcreFarm Member
| Subject: Re: Hydro Question/ problem January 25th 2013, 11:37 pm | |
| Depending on model, Max input speeds are anywhere between 2000-4000 RPM.
| Subject: Re: Hydro Question/ problem January 27th 2013, 5:14 pm | |
| I connected the trani to my corded hilti drill which runs at 1400rpm. It turned the axle but not at amazing speed, what is the small leaver for next to the input shaft? | |
| Subject: Re: Hydro Question/ problem January 27th 2013, 7:49 pm | |
| Its probably your FNR valve lever.
On some it ma be a hi/low range lever. | |
| Who is online? | In total there are 86 users online :: 0 Registered, 0 Hidden and 86 Guests
