 spicer tansaxle lost 6th gear i think
jaymz_eric
6 posters
jaymz_eric
spicer tansaxle lost 6th gear i think Empty
PostSubject: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 8:21 pm
the spicer transaxle in my lt1000 is loosing 6th gear, all the other gears work fine but 6th gear, no matter wat speed lunges real bad like it has teeth sheared off the gears or sumtin...any any ideas wat could have happened?
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 8:29 pm
I think the gear got work out either where the shift keys move in or maye a few teeth broke off. Probably gonna have to open it up.
avrappy
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 8:50 pm
You should open it up. I opened mine. I was told mine had been replaced with a 5 speed. Turned out to be a 4 speed. I have the old one. It looks like they are the same. The 4 speed just has the gears aranged different. Biger steps between gears. I could make mine a six speed If I want. The just put spacer bearings in place of the missing gears. The only diff. is my new one has only one leg on the shift fork not two like the other one does. I would guess it's for being a shift on the fly.
jaymz_eric
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 9:32 pm
i dont wanna get into rippin it apart agian, at least not right now, i'll just stick with my 5 gears i have left lol
AcreFarm
AcreFarm
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 9:38 pm
If the shifter is moving all the way and the detent ball is holding it in 6th, my money is on broken shift key(s).
jaymz_eric
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 9:41 pm
yeah it was doing some gawd awful clackin in 6th gear spinning the ag tires in the snow/ ice trying to get traction.....ever since then it was jacked up.....maybe i will take it apart you guys got me curious now lol
AcreFarm
AcreFarm
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 12th 2013, 9:46 pm
I know it's a pain, but taking it back apart is a good idea. You don't want pieces of shift keys moving around in there; I've seen a case crack when a piece of shift key got into the gearset.
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 13th 2013, 3:09 pm
I was fearful of opening up the gearbox on my 99 weedeater - after it locked on me. I figured since i had a spare trans, if it was broken- then could swap it out.
I looked up 'lynolsoffice' on YT and he had how to open up a peerless trans :
https://www.youtube.com/watch?v=ucbJ3Y-q1_c
https://www.youtube.com/watch?v=7_Pf5UKd89U
Watching his video helped me fix my trans - the indexer shaft was all rusty - so after some polishing with sandcloth - cleaned the whole thing, greased it up and slapped it back together - still runs awsome today.
This guy has a spicer trans rebuild video:
https://www.youtube.com/watch?v=pcDBdtxiyK8
Take your time, work careful and clean and it should go like clockwork.
jaymz_eric
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 13th 2013, 10:43 pm
im not afraid of whats in it, the previous owner apperently tried getting into it and stripped a bolt out and then apperently tried to either drill it out or chisel it out, worse part is its down in this little square recess ontop the trans, no room to get it with vice grips or anything
Chopperhed
Chopperhed
PostSubject: Re: spicer tansaxle lost 6th gear i think   spicer tansaxle lost 6th gear i think Icon_minitimeJanuary 13th 2013, 11:01 pm
\Can you cut the head off with a zip disc, and then remove the remainder after you have the case split?
Its worked for me on several occasions.
» craftsman FNR tansaxle stuck.....
» Need help figuring out if I blew my tansaxle!
» Peerless 930 4spd Good or Bad
» Spicer replacement
» Spicer transaxle
