| Low tire pressure traction idea and new modification I put on my tractor. | |
+8TheEquineFencer Chopperhed AcreFarm W1ldyOvvnZ theswampmachine dangeroustoys56 Doug CraftsMAN 12 posters |
CraftsMAN Member
![CraftsMAN](https://2img.net/u/2812/37/66/46/avatars/43-71.jpg)
Age : 38 Join date : 2010-06-01 Points : 5713 Posts : 364 Location : NY
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Low tire pressure traction idea and new modification I put on my tractor. January 12th 2013, 12:37 am | |
| So as many of you know that traction is key when offroading I remember I had on my jeep an onboard air compressor system to inflate and deflate my tires for rock climbing and snow wheeling. I recently aired my 2 rear tires on my craftsman down to 4psi and it performed very well in low gear. I decided to run a cheap walmart 12v air compressor off of my tractors battery so I could fill the tires back up again. The sidewalls of the atv tires will take a lot of abuse. Check out the video below at 2:00 in he plays with the tire pressure. Just another idea I figured I would add to my tractor. The compressor comes in handy to say the least. Will post photos soon. https://www.youtube.com/watch?v=55-CNzP19ds | |
CraftsMAN Member
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 12th 2013, 12:49 am | |
| I also had an idea for a 4wd tractor using a hydraulic driven front axle. I was looking for a tractor with loader when I came across the ad below. I talked to the owner of the tractor who said that he was able to convert this 420 2wd tractor in to a 4wd unit using a hydraulic driven front axle. I know it would not be extremely hard to run a hydraulic pump off of the electronic PTO and that would enable a 4wd set up that you can switch on and off with the push of a button to activate and deactivate the pump. Anyway the guy said that the 420s front axle comes in handy in the snow and the front tires can spin no problem even under loads. Pritty cool? http://rochester.craigslist.org/grd/3529897526.html | |
Doug Site Owner
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | |
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
theswampmachine Member
W1ldyOvvnZ Member
![W1ldyOvvnZ](https://2img.net/u/2812/37/66/46/avatars/230-55.jpg)
Age : 28 Join date : 2011-12-06 Points : 5177 Posts : 499 Location : Winchester, ON, Canada
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 15th 2013, 11:22 pm | |
| i dont think the 12v air compressors work to well(i never had luck with them, the most i ever got one to get upto was 5 psi, i had two so i took them and made the two into a steam engine but it didnt work out so well because i couldn't weld the aluminum well(kept burning through because it was to thin and wasn't that good of aluminum), then i tried welding a hole shut and blew through one cylinder head. but the 12v air compressors i did use were used ones that i found so that's probably something to do with my luck also(the ring looks to be nylon so i don't think they are designed to last a long time). maybe if i buy one i will try it out, what happens if you pop your bead out in the middle of the trail? | |
Doug Site Owner
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 16th 2013, 12:00 am | |
| - W1ldyOvvnZ wrote:
- i dont think the 12v air compressors work to well(i never had luck with them, the most i ever got one to get upto was 5 psi, i had two so i took them and made the two into a steam engine but it didnt work out so well because i couldn't weld the aluminum well(kept burning through because it was to thin and wasn't that good of aluminum), then i tried welding a hole shut and blew through one cylinder head.
but the 12v air compressors i did use were used ones that i found so that's probably something to do with my luck also(the ring looks to be nylon so i don't think they are designed to last a long time). maybe if i buy one i will try it out, what happens if you pop your bead out in the middle of the trail? Ive used ratchet straps to seat the bead of my Agway tires because ther im was too wide for the tire. It would work basically the same way but better fi your tire matches your rime (stretched tires are a paint to seat). Plus its pretty hard to crack a bead. You would have to be running your tires really low and do some good damage go get it to pop off. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
W1ldyOvvnZ Member
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 16th 2013, 7:38 am | |
Plus its pretty hard to crack a bead. You would have to be running your tires really low and do some good damage go get it to pop off. i know what your talking about with the ratchet strap, thats what we do with out lawn cutting mowers(it always pops of the bead just sitting, the tire has a slow leak), when me and my friend were driving his mudding tractor through a feild we popped the tire off the bead(dont know how many psi were in the tire before we went out though, i just thought 4psi was on the low side but i guess if some ATV tires running pressure are 5 its not that low) | |
AcreFarm Member
![AcreFarm](https://2img.net/u/2812/37/66/46/avatars/206-76.jpg)
Age : 40 Join date : 2011-11-02 Points : 4862 Posts : 208 Location : Tennessee
W1ldyOvvnZ Member
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 16th 2013, 10:49 pm | |
| - dangeroustoys56 wrote:
- If popping beads off is an issue - do as the offroaders do - bead locks. Shouldnt be that hard to do ( time consuming but not that hard).
Thats what i was thinking of doing, im not going to do it anytime soon because i have aluminum rims and i would like to see if i have issues with my tires and rims. and ive never really seen beadlocks in person, they have the outer ring on the outside of the rim and i assume the same on the back side? | |
Chopperhed Moderator
![Chopperhed](https://2img.net/u/2812/37/66/46/avatars/469-45.jpg)
Age : 58 Join date : 2012-10-14 Points : 5180 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. January 16th 2013, 10:56 pm | |
| Can you find/cut slash/modify/hack a set of ATV rims. They are beadlock style already, they are damn hard to pop a bead on. GT rims tend to pop beads, alot, especially under low pressure conditions,(ie flat)
ATV beadlock style rims have a standard bead and shoulder on the rim, and an inner raised rib on the inside of the tire bead ( as differntiated from the rim bead). believe me they take a machine to pop the bead. I've tried all the old skool trick to pop them and the only way I've found is to use a machine. They ncan also be bitchy to mount, but worth it.
W1ldyOvvnZ Member
Doug Site Owner
TheEquineFencer Member
Join date : 2013-02-19 Points : 4347 Posts : 90 Location : Farmville,NC, USA
CornishMorgan Member
![Low tire pressure traction idea and new modification I put on my tractor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Low tire pressure traction idea and new modification I put on my tractor. February 23rd 2013, 6:06 am | |
| - TheEquineFencer wrote:
- theswampmachine wrote:
- I would put train horns on it if you have a compressor and a tank... That would be awesome
Real "train horns" start around $5000 USD for a "kit". I have a buddy with a set, that's what he has in it.
I have put two sets of air horns in my car and set them up with 2 high notes on one compressor and 2 low notes on the other compressor. My car now can sound like a British train with its tow tone air horns. I have kept to stock horn in so i technically have 3 horns on my car Check out my video of them here | |
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
truckin42 Veteran Member
![truckin42](https://2img.net/u/2812/37/66/46/avatars/462-16.jpg)
Age : 26 Join date : 2012-10-04 Points : 5429 Posts : 1070
![Ariens YT11](https://2img.net/u/2812/37/66/46/avatars/482-72.jpg)
Age : 27 Join date : 2012-10-31 Points : 5090 Posts : 745 Location : The Wyo-Braska Panhandle
