 Water Sprayer Proof Of Concept Idea
Tractor Man Jeff
CornishMorgan
6 posters
CornishMorgan
Water Sprayer Proof Of Concept Idea Empty
PostSubject: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 26th 2012, 1:44 pm
Water sprayer for my Dynamark Lawn Tractor. Proof of concept idea and test.
Remember to Rate, Comment and Subscribe to my youtube channel Very Happy
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 27th 2012, 11:45 am
Hey, Lookin good. Add a big water or chemical tank and a small 12V sprayer pump on there and ya got something really nice.
moremorelawnmowers
moremorelawnmowers
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 28th 2012, 5:02 pm
I have been thinking of buiding something like that so I can water my garden. Looks good.
https://www.youtube.com/user/moremorelawnmowers?feature=mhee
Chopperhed
Chopperhed
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 28th 2012, 5:56 pm
All kinds of good easy ways to do it.
There are atv, tractor, truck mounted setups and trailer setups.
How much water do you plan to haul?
Water is 10 pounds a gallon roughly, and your tires and axles will need to be able to carry it.
Also, a lot of the factory units and some of the truck mounted ones I've seen, use a flip down boom to widen the soak area. and also some have a hose attachment for spot watering.
just some ideas.
http://www.princessauto.com/pal/product/8260846/Atv-Mount/25-Gallon-ATV-Mount-Sprayer
http://www.princessauto.com/pal/product/8141228/Towable/25-Gallon-Sprayer-with-Twin-Nozzles
moremorelawnmowers
moremorelawnmowers
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 28th 2012, 7:01 pm
When I build mine I plan to use a plastic 55 gallon drum. So mine will have to hold about 550 pounds. I plan to mount it on a trailer to tow behind my lawn tractor. I want to use the same method to spray the water but put the pipe on the back and the sides to cover a larger area. I also want a hand held sprayer to water the taller plants I cant drive over. I plan on using a little 2 stroke water pump from northern tool to fill the tank and to spray the water. I probably wont build mine till spring because I have no use for it now.
Craftsman Dude
Craftsman Dude
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 28th 2012, 8:00 pm
My dad built a spraying arm off the side of his snapper for putting grass killer on fence rows it was the windshield washer setup of a ford explorer wired to a swith worked great only problem was it didnt have a big enough resivor but you could adapt the pump to something bigger.
dked41
dked41
PostSubject: Re: Water Sprayer Proof Of Concept Idea   Water Sprayer Proof Of Concept Idea Icon_minitimeDecember 29th 2012, 1:13 pm
The initial setup will work good for the deicer , but probably won't be effective for making mud. You would need a valve in the center, when closed the water flows out the holes in your pipe, when open it would dump out the valve like a faucet. The valve I would use would be 1 1/2 inch or so for more water. The pipe with holes will make mud, but how many passes would it take to get enough water down? The open valve would get more water down faster.
» Sprayer project.
» Block heater...good idea, bad idea, just plum stupid?
» The Bullet proof, Indestructable, Off Road Pedal Car.
» Ice water challenged!
» water in trans
All-Terrain Lawn Tractor Forum :: General Tractor Talk + Pictures/ Videos :: Pics and Videos-
