| What type of fuse should I use for 1978 Montgomery Ward? | |
+3dangeroustoys56 gearheadmike BlackMountian88 7 posters |
BlackMountian88 Member
Junkstarbuilds Administrator
Age : 48 Join date : 2012-07-03 Points : 4843 Posts : 236 Location : Fort Stewart Georgia
| Subject: Just did the same December 11th 2012, 4:41 pm | |
| I just posted an update myself because I had to rewire a mower today. It's on my site as the latest video | |
Age : 25 Join date : 2012-09-08 Points : 4893 Posts : 399 Location : NH
| Subject: Re: What type of fuse should I use for 1978 Montgomery Ward? December 13th 2012, 12:40 pm | |
| Ok guys, I tried her out today, an pow, there goes the fuse. So I said to myself, forget it. I put a jumper wire in where the fuse should go. Tried it. And there was a flash and smoke and the jumper wire fried. Where do I go for here? | |
| Subject: It just not wired right December 13th 2012, 1:08 pm | |
| You have something not wired right. We need to walk through each wire. Starting from your battery | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: What type of fuse should I use for 1978 Montgomery Ward? December 13th 2012, 1:34 pm | |
| - BlackMountian88 wrote:
- Ok guys, I tried her out today, an pow, there goes the fuse. So I said to myself, forget it. I put a jumper wire in where the fuse should go. Tried it. And there was a flash and smoke and the jumper wire fried. Where do I go for here?
You have a dead short somewhere . | |
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4808 Posts : 141 Location : central Wisconsin
| Subject: Re: What type of fuse should I use for 1978 Montgomery Ward? December 13th 2012, 1:44 pm | |
| How is your kill switch wired? it should not go to a ground. It should be an ignition on and off and should power the coil and could run the shut off solenoid too. The engine is alternated and does not use a magneto kill system. | |
dked41 Member
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5206 Posts : 392 Location : west chazy ny
dked41 Member
| Subject: Re: What type of fuse should I use for 1978 Montgomery Ward? December 17th 2012, 11:38 am | |
| Both of the engines used in mine, are wired the same. Both engines have alternators and are not magneto fired. I would scrap all the old wiring and start over using a diagram from a tractor that used that 2007 Briggs engine. | |
maxrpm1224 New Member
Join date : 2013-01-08 Points : 4343 Posts : 5 Location : maryland
