 Very fast lawnmower question
5 posters
CraftsMAN
CraftsMAN
Very fast lawnmower question Empty
PostSubject: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 3rd 2012, 11:03 pm
So I am building a tractor with a motorcycle engine and a go kart style rearend. like the one in this video below. I was wondering for the rear axle I got a 32x1 inch go kart axle. Should I use a pillow block bearing that will attach to the stock tranny mounts on a lawnmower. Or should I drill a hole through the frame and mount 2 bearings on the frame of the tractor? I am sure I will be asking more questions as times go on.
https://www.youtube.com/watch?v=yAW1wg_WJwA
https://www.facebook.com/CRUSHEMCustoms/
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 3rd 2012, 11:11 pm
Oh the tractor is a craftsman old grey one..
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 5th 2012, 8:44 am
I suggest pillow blocks, mainly for the high RPMs , strength and servicability ( can grease em) - they work for building ventilation systems so should work great on a tractor - all my mods are using pillow block berings.
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 9th 2012, 3:45 pm
I picked up a 32x1 inch axle for it with 2 of these bearings (http://www.ebay.com/itm/2-DODGE-F4BSC204-2-1-4-4-BOLT-FLANGE-BALL-BEARINGS-/271098320214?pt=LH_DefaultDomain_0&hash=item3f1eb81556)
What I also wanted to know is what do I do to keep the sprocket from moving from side to side when I put it on the axle shaft?? I imagine it goes on with a keyway but do I use a spacer to hold it center? Thanks Smile
AcreFarm
AcreFarm
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 9th 2012, 5:25 pm
You can use lock collars to keep the sprocket from floating on the axle.
You should be able to find them at TSC, NAPA...etc.
Or online
http://www.mfgsupply.com/gomini/gominisprockets/gominisprocketscollar.html
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 9th 2012, 11:38 pm
What size sprocket should I use?
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 9th 2012, 11:58 pm
How do I make sure the lock collars do not move around? The threads might not hold up on the bolt to tighten them....
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 10th 2012, 12:34 am
Lock collars do a great job of staying where they are supposed to... we use the crap out of them.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 10th 2012, 1:14 am
Couple of ways to lock set screws down so they don't move
Before you install the setscrew take a drill and bit smaller than the ID of the threads, and drill a dimple in the shaft. It doesn't take much of a dimple.
Then use some thread locker on the set screw to keep it from backing out. Red if its permanent, Blue if you want to take it apart later. Or if you are really cheap and don't care if it comes out, Superglue makes a good thread lock, It may or may not come apart afterward though
Or you can skip the dimple and just use the threadlocker, pretty weak though
I personally would drill and tap for a second set screwm opposite the first, dimple both, and Loctite them in
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 20th 2012, 10:52 pm
AcreFarm
AcreFarm
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 21st 2012, 1:29 am
Looks like direct steer versus rack & pinion...
They would both work, it just depends on your preference. Some people would say not to use direct steer on an off-road machine... some would say go for it.
I built a direct-steer setup on my mower, mainly because I prefer a hand throttle over a foot throttle. Honestly you will get a whole lot more feedback from a direct steer... as you hit & run over things the steering wheel will want to jerk left or right. The rack & pinion steering will feel closer to a stock mower setup; it will take multiple turns of the wheel to go full-lock to the left or right. Like a kart vs. a mower... it will steer slower, but with less feedback thru the steering wheel.
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 21st 2012, 4:07 am
I would be using a foot throttle..
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 21st 2012, 5:44 am
I need room under the hood so steering cant get in the way. I would like to keep the steering under the frame if possible. Here is my most recent video.. https://www.youtube.com/watch?v=R3TAI3c9xzM
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 22nd 2012, 6:15 am
So what size sprocket should I use? I want a good balance of top end and low end.
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 22nd 2012, 9:43 am
I Need to know a few things
First off which engine are you using?
Make and model of the bike its coming from is all I need to know
Output sprocket size on the engine, are you using the shifter, or will it be in locked in gear?
Tire size
expected top speed
I should be able to find the gear ratios for the engine on line, if not, the engine sprocket size is all i need
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 3:24 am
The rear tires are 18x8.5x8 and the engine will be a 400cc yamaha engine most likely. I will be using the shifter. Expected top speed not really worried. About 50 lets say ?
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 7:48 am
Is it a dirt bike ir street bike engine, 2 stroke or 4 stroke
Do you know the model of the bike its coming from?
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 11:31 am
I just ran the numbers using the stock Yamaha XS 400 twin with a stock 16 tooth sprocket, assuming a 4th gear ratio of 1 to 1 ( 5th and sixth gear are usually overdrives) Its the only old yamaha 400 with electric start. Using a kick start engine in a tractor would be a pain.
with a 60 tooth rear sprocket you would expect a top speed of 100 mph @ 7000 rpm
a 70 tooth sprocket would get you down to 85 mph, however a 70 tooth sprocket is huge, nearly the size of the tire
if you add a jackshaft with a 20 tooth input sprocket and a 10 tooth output sprocket and use a 50 tooth rear sprocket you can cut you're top speed to 60 mph @ 7000 rpm.
if you add a jackshaft with a 32 tooth input sprocket and a 10 tooth output sprocket and use a 40 tooth rear sprocket you can cut you're top speed to 45 mph @ 7000 rpm.
How much pulling power do you want?
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 4:55 pm
It would be off of a street bike 4 stroke. I would like some good low end..
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 5:35 pm
All the old yamaha 4 stroke 400s were about the same horsepower. I wouldn't bother trying to use a kickstart motor, unless you can figure out some fancy rigging to actuate the kicker. A 400 single is damn hard to kick over even for me, and I weight 240 lbs. Doing it on a tractor would be extremely difficult.
"if you add a jackshaft with a 32 tooth input sprocket and a 10 tooth output sprocket and use a 40 tooth rear sprocket you can cut you're top speed to 45 mph @ 7000 rpm."
This forumula should work quite well, You pretty much have to run a jackshaft or you won't get nearly the ratio you need to get the speed down to 50 or so. The formula is based on the Yamaha 400 twin with a 16 tooth engine sprocket.
A 70 tooth sprocket is 14-1/2" around and it will get you down to 85 mph with out a jackshaft, but you won't have much bottom end.
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 5:50 pm
This might sound stupid but I have no idea what a jackshaft is..
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 5:51 pm
Like a dual chain set up?
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 29th 2012, 6:42 pm
a jackshaft is a shaft between the engine and your axle. It can be used to correct alignment issue, or for extra gear reduction.
It is basically a shaft with 2 sprockets on pillow block bearings, sprocket sizes determin the ratios.
http://en.wikipedia.org/wiki/Jackshaft
Very fast lawnmower question Yellow10
CraftsMAN
CraftsMAN
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 30th 2012, 2:30 am
Oh I see now. I am unsure if I have the room to run one of those? I am going to pick up the engine tomorrow. It should have all of the wiring but if it does not ebay will be making some $ off of me. lol. As for kick start check out the first link. The second link is of the tractor so far.
https://www.youtube.com/watch?v=ePt0WgWZZ0Y
https://www.youtube.com/watch?v=TBtjV2SRyUs
Chopperhed
Chopperhed
PostSubject: Re: Very fast lawnmower question   Very fast lawnmower question Icon_minitimeNovember 30th 2012, 9:52 am
I need to know the model of the bike for any better info.
an 80 tooth #50 sprocket is 16.5 inches in diameter. you'ld only have an inch or so clearance under the sprocket.
A jackshaft only takes as much space as the largest sprocket plus a little for chain and guard clearance.
Mine only uses a roughly 5"x 5" area 12" wide, and it could be narrower, I could have used a shorter shaft.
» lawnmower drive pulley question
» Rat rod lawnmower
» how fast should this go
» Whats the most heaviest duty rear end?
» jb weld lawnmower dif?
