 Can you put a pushmower engine on a lawn tractor?
moremorelawnmowers
greener179
crafsmankiller
8 posters
crafsmankiller
Can you put a pushmower engine on a lawn tractor? Empty
PostSubject: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeOctober 30th 2012, 8:51 am
I have a 20 horse engine that doesn't run and I was wondering if I could put a pushmower engine in it's place
greener179
greener179
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeOctober 30th 2012, 9:17 am
are u going to be running the deck?
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeOctober 30th 2012, 9:34 am
This one guy on you tube did that on a murray he had - pretty much for buzzing around with . I can tell you that owning a few stock 5HP tractors, you wont be able to run a deck with a 3HP motor - 5HP can barely handle it.
crafsmankiller
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeOctober 30th 2012, 10:07 am
No deck.it's the same mower as in my other post. It's only gonna be used for fun
moremorelawnmowers
moremorelawnmowers
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeDecember 28th 2012, 12:02 pm
Your going to need a cast iron flywheel or a heavy pulley to put on the crankshaft since its a push mower engine. It will kick back with out it.
https://www.youtube.com/user/moremorelawnmowers?feature=mhee
crafsmankiller
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeDecember 28th 2012, 8:37 pm
i found that out the hard way, tried to start it w/out the blade and nearly broke my wrist. im not really concerned with this mower anymore as im working on my murray lawnchief RER. its been sitting foir a couple of years and i need to get it running.
tractorboy567
tractorboy567
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeJanuary 23rd 2013, 4:37 pm
just use a pushmower engine for riding around on a flat surface because it is so limited on power
DG350
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeJanuary 23rd 2013, 5:27 pm
I don't understand what happens when you try pull starting it without a blade. I know the engine was designed to have a relatively heavy flywheel (blade) on the output shaft, just didn't know what kind of affect it would have with it missing. Does the engine jerk back in reverse rotation when it doesn't start because of the compression stroke?
cumminsbayou
cumminsbayou
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeJanuary 23rd 2013, 8:44 pm
the pulley would be enough weight for it but you wont have torque but it would be good for speed with i good pulley swap
Chopperhed
Chopperhed
PostSubject: Re: Can you put a pushmower engine on a lawn tractor?   Can you put a pushmower engine on a lawn tractor? Icon_minitimeJanuary 23rd 2013, 9:36 pm
3hp in a tractor built for 20hp is hardly going to be able to move it.
In a smaller RER it would work,
» best looking rear engine lawn mower?
» Run a lawn mower off old engine oil/diesel/bad gas/kerosene
» Engine powerd lawn mower snow blower?
