| Generators | |
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7001 Posts : 1726 Location : Florida, USA
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Generators May 20th 2010, 6:18 pm | |
| Back when we were up north, my dad bot a $150 king craft 2000 watt generator from Aldi's- wife almost bot one- just for emergencies here in the south.
Pop still hasnt fired up his generator yet, but today we went to a nearby Aldis and found a 3200 watt 6.5HP powered king craft generator for $200 - looks darn close to my dads homelite generator he bot many years ago- supposedly the run time is 11HRs at half load. Basically we plan to just run our freezer and fridge in case of a power outage - possibly a fan as well. Ive been meaning to get one sometime because of hurricane season is getting close.
Only thing stopping me from starting it is they suggest 10w30 or 30 weight oil - which i have neither around- figure ill put new oil in, run it a few times, then drain the oil and run it again, while testing the output of it.
Its a bit hefty, so ill make a whole new frame and mount some lawntractor wheels under it .
The only sorta thing im curious is that its a chinese built generator...not my first choice but was the right price- if it lasts years into the future- then ill be satisfyed.
Keep y informed on it. | |
Chunk Established Member
![Chunk](https://2img.net/u/2812/37/66/46/avatars/2-3.jpg)
Age : 33 Join date : 2010-02-10 Points : 6145 Posts : 779 Location : Angus, Scotland
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 3:00 am | |
| Cant wait to see how it pans out. We got a genny with a clone motor, not had any problems yet, although its still fairly new. I need to swap the oil from the run in oil to fully synth. | |
arild365 Member
![arild365](https://2img.net/u/2812/37/66/46/avatars/6-25.jpg)
Age : 29 Join date : 2010-02-11 Points : 5738 Posts : 320 Location : Canada, BC
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 9:57 am | |
| when we moved to this house about 5-6 years ago, it was a junk yard. there were cars, tools magazines push mowers and hell even a couple lawn tractors ![Sad](https://2img.net/i/fa/i/smiles/icon_sad.gif) its too back i didnt clue in and realise all the fun sittin there. i didnt get into the sport back then ![Sad](https://2img.net/i/fa/i/smiles/icon_sad.gif) it took use( 8 going on 9) too move all that shit a couple week well now to the point of my story. i was in the tool shed (that was here when we got the place) a couple months ago and was lookin for a bolt or sumthing and saw a red thing. after a good 2 hours i pulled out this old briggs generator. I think its a 12 horse not too sure but its heavy. after a hour and a half it fired right up i was supprised. Mustve been sitting around 10 to 20 years! | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 10:16 am | |
| I really love your property, loads of great palces to go mudding, and just generally store 'junk'
Is a shame you didnt get those lawn tractor, but hell, cant win em all. | |
arild365 Member
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 10:18 am | |
| haha yah i love how much room there is here. cant get anything and just store it away. i actually just cleared another path to a nice muddin hole yesterday. | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 10:19 am | |
| Cant wait to see more vids. You should do a tour of your property sometime! | |
arild365 Member
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators May 21st 2010, 10:21 am | |
| yah sure thanks for the vid idea. its pissing rain right now so when it clears up il do it... hopefully ![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif) | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 1st 2010, 6:21 pm | |
| Update: I decided to fire up the new generator today- hauled it out onto my steel sawhorses - took the plug out, sprayed some PB blaster in the combustion area , put lucas oil and pennzoil SAE 30 into the pan, pulled it over a couple times to get things working smooth. So put the plug back in, added a lil bit of gas in it , turned the choke on and the gas on - second pull it fired right up. I was impressed how easily it fired up. I ran it like 15 mins with no load, then put a box fan on it for like another 15 mins, then ran my air compressor on it for another 15 mins- ran nice n smooth! It ran out of gas, it was hot enough so i changed the oil again - i probably didnt have to, but i did anyway- it suggests to change it every 20 hours. I was really impressed on how quiet it was and how smooth it ran. Ill be ready if any hurricanes come thru this year ( they say it might happen) ![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif) | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 5:29 am | |
| Sounds awesome. 20 hours seems a little excessive though?
Talking about hurricanes, anyone seen that sinkhole? That really scares me, the fact that what you thought was solid ground falls into a 330ft deep hole! | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 6:33 am | |
| Well, generators rev pretty high - even at idle it runs pretty fast. When i run it again ill probably change it after that - itll sit probably more then itll be used - pop said run em like once a month or so to keep em all good. I do need some gas stabilizer tho.
Sinkholes? Theyre all over down here- the sandy soil and water dont mix .
I was watching some show on TV once - this guy was at a gas station was pulling up to a pump and fell into a giant sinkhole right near the pumps - like opened up right under his truck. That was creepy. | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 10:00 am | |
| ![Generators 0601dv_guatamala_sinkhole](https://2img.net/h/images.chron.com/photos/2010/06/01/21890128/0601dv_guatamala_sinkhole.jpg) Thats the one Im on about. Thats more than 2 Statue of Liberty's deep! Right out of no where. Swallowed a house without warning. Thats scary! Unfortunatly the high res photo I found on wikipedia the other day has been removed. | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 2:44 pm | |
| holy crap! wheres that again? Thats like halfway to china....... | |
Guest Guest
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 4:25 pm | |
| lol wonder what causes them, i have a neighbour i wouldnt mind letting "sink" |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 4:39 pm | |
| That happened recently in Guatemala, its been in the news. A trpocial storm caused it I think! Apparently it only happens in aread where the underlying ground is liable to erosion from water ![affraid](https://2img.net/i/fa/i/smiles/affraid.gif) | |
Webmaster Webmaster
![Webmaster](https://2img.net/u/2812/37/66/46/avatars/1-56.png)
![Webmaster Webmaster](https://i.servimg.com/u/f62/19/56/75/89/y310.png)
Age : 14 Join date : 2010-02-09 Points : 5660 Posts : 332 Location : Here!
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 6:58 pm | |
| Damn, I wonder where all the soil went... What would you fill it in with? About 100,000 tons of rip-rap? | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 9:05 pm | |
| Not much you can do but go golfing- if ya cant hit THAT hole in one- you shouldnt play golf- LOL! | |
Webmaster Webmaster
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 2nd 2010, 10:00 pm | |
| That sinkhole is ALMOST as big as the one in the road, on the way to my parents house... When I first saw that picture, it reminded me of my bank account! I also kinda reminds me of a girl I knew in high school... J/K!! Sorry to hijack your thread, but I couldn't resist! | |
![Generators Empty](https://2img.net/i/empty.gif) | Subject: Re: Generators June 3rd 2010, 5:59 am | |
| Landfill! lol. I dont know, I was wandering that too. It's not like you can just ignore it either! | |
![Generators Empty](https://2img.net/i/empty.gif) | |
| Generators | |
