| 4x6 Murray mud mower | |
Bandit1 Member
Age : 29 Join date : 2012-08-21 Points : 4531 Posts : 43 Location : kansas
| Subject: 4x6 Murray mud mower August 22nd 2012, 12:27 am | |
| I'm working on adding another transmission to the back end of my lifted mower. I'm building it so it is completely independent from the main mower. I was wondering how y'all think it would do in mud?? | |
| | | cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5021 Posts : 232 Location : fairhope Al.
| | | | Bandit1 Member
| | | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: 4x6 Murray mud mower October 25th 2012, 12:31 am | |
| All kinds of ideas need more info
Motor, frame, driveline options, what do you have to work with, need pics man. | |
| Subject: Re: 4x6 Murray mud mower October 25th 2012, 7:32 pm | |
| I was close to making a 4x4 from my agway ( looks just like yours) - till i got a beefy GT murray - i was gonna add a peerless 5 speed up front with a setup similar to a noma 4 wheel steer setup - and 4 atv wheels/tires. | |
| | | Bandit1 Member
| Subject: Re: 4x6 Murray mud mower October 26th 2012, 4:54 pm | |
| Ill try to post some pictures tonight if I can figure out how to post them.. I'm using the original stamped steel frame and I'm going to try and use a belt drive if it can handle the flex. | |
| Subject: Re: 4x6 Murray mud mower October 27th 2012, 4:31 pm | |
| I figured if i put the trans up front , id need to reinforce it or build a sub frame, pretty much for me to mount the steering stuff to.
When i ran my agway thru a swamp behind the folks house - it was totally stock, i swapped on some turf tires for turning traction up front , had planned on getting AGs for the back , if i kept it up there.
It did surprising well for a stock setup, the rear tires just spun alot, even running a couple PSI in the tires. I did the large front tire swap, mild drive pulley swap ( not for high speed, just for a lil more then geriatric stock low speed)- then my nephew told me about this GT for cheep ( has no motor) - so i put the agway back to stock. | |
| | | Bandit1 Member
| Subject: Re: 4x6 Murray mud mower October 28th 2012, 9:43 am | |
| I would put it up front but I don't have a transmission off of a rear wheel steer. The only way I would know to do it without one would be by makeing my own frame that articulates in the middle. I really don't want to have to build a whole new frame make it work though. If you have any ideas please let me know. | |
| Subject: Re: 4x6 Murray mud mower October 29th 2012, 7:14 pm | |
| Im going to get some steel and attempt at making my own steering setup - i have a few good pics off ebay of noma all wheel steer transmissions - it doesnt look like itd be that hard actually - trip to TSC for a couple 3/4" u joints, couple hiem joints - some welding and fabrication it should work , unless someone else is selling a cheeper complete or steering setups off a noma tractor - one i saw the guy wanted $500 for the whole thing - i can build one cheeper.
When i get around to working on it ill post pics ( id say after the holidays most likely). | |
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
