| power or speed | |
+3Jamus WellThatsSurprising brownjon4 7 posters |
brownjon4 Member
Age : 39 Join date : 2012-06-10 Points : 4591 Posts : 30 Location : ohio
| Subject: power or speed August 18th 2012, 8:46 pm | |
| I was jw if i changed the tranny pulley but leave the engine stock would it give me speed or power or both | |
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5010 Posts : 407 Location : East Bethel, MN
brownjon4 Member
| Subject: hello August 18th 2012, 8:59 pm | |
| I did a pulley swap on my other mower but i changed the engine and the tranny pulley on it so i didn't even need to change it to get the speed i wanted ? | |
| Subject: Re: power or speed August 18th 2012, 9:04 pm | |
| ... I don't think I understand your question | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5809 Posts : 511 Location : Southern WV
| Subject: Re: power or speed August 18th 2012, 9:53 pm | |
| Looks like a statement with a question mark attached to the end to me. | |
brownjon4 Member
matthew sidor Member
Age : 30 Join date : 2012-04-13 Points : 4794 Posts : 184 Location : Montesano, Washington
| Subject: Re: power or speed August 19th 2012, 1:25 pm | |
| Smaller on the engine = more power less speed... Larger on the engine = more speed less power... Smaller on the tranny = more speed less power... Larger on the tranny = more power and less speed... | |
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4811 Posts : 141 Location : central Wisconsin
| Subject: Re: power or speed August 19th 2012, 10:47 pm | |
| The two pulleys together set a ratio, think of a ten speed bicycle and the gears . smaller front (engine)+ big rear(trans) = lower speed but easier turning (more power) Then change it to big front+ small rear= more speed but harder to turn (less power) The fact that the transaxle has more than one gear allows speed at high gear but lets you retain some power at low gears even with a pulley swap. So to sum it up both pulleys work to set the final drive ratio. | |
brownjon4 Member
| Subject: hello August 20th 2012, 11:02 am | |
dked41 Member
| Subject: Re: power or speed August 20th 2012, 11:12 am | |
| Just changing one pulley will still change the ratio. I don't know if it will be enough to do what you want to do. You will also have to change the belt size, to keep the clutch pulley at the proper tension. Too long a belt and it will slip, too short and it won't release. | |
brownjon4 Member
| Subject: hello August 20th 2012, 1:27 pm | |
| well do you have any info on how I can make that happen I was thinking with all that weight. In the back it would pop. Whellies just by poping the clutch | |
brownjon4 Member
| Subject: hello August 20th 2012, 7:53 pm | |
| What if I have small pulley on engine and tranny what would happen there | |
| Subject: Re: power or speed August 21st 2012, 2:53 am | |
| umm thats a good question when u have small one on the engine u get more torque and when u have a smaller one on the transmission u get speed. idk how that would work i want to know how that works. | |
brownjon4 Member
| Subject: hello August 21st 2012, 9:49 am | |
| I am going to try it soon
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5704 Posts : 1091 Location : Galion, OH
| Subject: Re: power or speed August 21st 2012, 10:33 am | |
| If you make both pulleys small, you will have less grip on the belt, so you will probably slip and/or burn up belts trying to do wheelies. If you are going to make both pulleys the same size, you should probably go bigger. I'll try to make what was stated earlier easier to understand: changing pulleys is about the difference in size between the engine and transmission pulleys. If a pulley is bigger, the belt has further to go each time the pulley turns. The effect of this is - If you increase the size of the engine's pulley and/or decrease the size of the transmission's pulley, the belt travels farther on the engine's pulley for each turn of the engine, so the transmissions pulley has to spin more. This makes the tractor go faster than before at a given engine speed. | |
brownjon4 Member
| Subject: hello August 21st 2012, 12:29 pm | |
| Thanks for the info it has help once I get my tranny back together and the carb rebuilt. I will let you guys no how it worked out thanks for the input | |
Age : 54 Join date : 2010-02-10 Points : 7079 Posts : 1726 Location : Florida, USA
| Subject: Re: power or speed August 22nd 2012, 7:20 pm | |
| I ran a 6" on the motor ( twin 18HP) and a 3" on the trans on my mod murray - even with a hand throttle it lagged - more then likely a different carb wouldve help , but motor lagged for just a few seconds then it was there - i didnt have any lack of power or speed once it hooked up - i wound the tractor to roughly 35mph before it was just too hard to control being nearly stock- it had ALOT more to go like 2 more gears and i wasnt even hardly using the motor power .
After that i wasnt interested in finding out what it had - wasnt worth going to the hospital if something happened - i took it apart. | |
| power or speed | |
