 B&S oil fill
2 posters
kazjanne
B&S oil fill  Empty
PostSubject: B&S oil fill    B&S oil fill  Icon_minitimeJuly 25th 2012, 5:05 pm
i've got an lawn mower with an briggs, only the last few times the motor started doing weird.
if i remove the oil pen while it's running oil will plump out of the thing, it didn't do that before, or at least i didn't notice.
but the oil level is good. the oil isn't the newest but it should work. i've got no idea , it started like at once.
so if anyone ever experienced something like this, please respond.
kaz
B&S oil fill  Empty
PostSubject: Re: B&S oil fill    B&S oil fill  Icon_minitimeJuly 26th 2012, 6:42 am
Actually you shouldnt remove the dipstick while its running - besides burning you with hot oil , it can easily loose most the capacity.
Only reason the oil level went up is because gas is leaking into the crankcase - which means time for a carb cleaning/rebuilding - oil capacity for single cylender is around a quart and quarter or so.
Smell the oil - if it reeks of gas - change it - if its left in there youll blow up the motor , gas will thin the oil and eventually gall the berings, ruining the motor.
Another reason oil could push out is built up crankcase pressure- meaning the breather is plugged.
B&S oil fill
