 3spd Gearbox pulley & chain what speeds are these good till?
2 posters
gearheadmike
gearheadmike
3spd Gearbox pulley & chain what speeds are these good till? Empty
PostSubject: 3spd Gearbox pulley & chain what speeds are these good till?   3spd Gearbox pulley & chain what speeds are these good till? Icon_minitimeJune 8th 2012, 9:49 pm
id like to build a racing mower and insted of going through the headache of jackshafts and that for when i lower the rear end i was thinking of going with a 3spd gearbox i have off a old murray rear engine. and then run a solid gocart axle in the rear but my question is what speeds are these gearboxes good till? i will be adding gearoil in it instead of grease.
PostSubject: Re: 3spd Gearbox pulley & chain what speeds are these good till?   3spd Gearbox pulley & chain what speeds are these good till? Icon_minitimeJune 8th 2012, 11:06 pm
I saw on heymow some guy used a 3 speed trans that came on a 70 toro - other then getting some upgraded parts for it, it's basically a standard trans.
Here's the link:
http://www.heymow.com/index.php?PHPSESSID=ukdvferp5j37thsmi05f0053k0&topic=14692.0
gearheadmike
gearheadmike
PostSubject: Re: 3spd Gearbox pulley & chain what speeds are these good till?   3spd Gearbox pulley & chain what speeds are these good till? Icon_minitimeJune 9th 2012, 9:24 am
This is the gearbox i have its a foote 3spd
3spd Gearbox pulley & chain what speeds are these good till? Foote2
3spd Gearbox pulley & chain what speeds are these good till? Foote1
» Need ideas on how to get higher speeds out of a FNR transaxle
» Would you use a chain or pulley type clutch and what ratio?
» what are some good pulley sizes
» MTD Variable Speed Pulley system: GOOD OR BAD?
» Craftsman II GT 18 3spd Hi-Lo diff question
