| The Rig mower | |
+7lawnzilla dagr8tim TheRainbowBoxer dangeroustoys56 Stretch44875 Jamus Therig 11 posters | |
Therig New Member
| Subject: Re: The Rig mower May 20th 2012, 11:41 pm | |
| Went offroading. today ive made a few upgrades like a mega bumper as well as a set of stack brackets to allow stacks to be doubled as bush guards and not bend or fall down. 4 went mudding 2 made it bad 2 went back down and only 1 made it back https://i.servimg.com/u/f46/17/46/26/15/04241210.jpg | |
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: The Rig mower May 21st 2012, 4:24 pm | |
| - Therig wrote:
- 4 went mudding 2 made it bad 2 went back down and only 1 made it back
I remember those days..... | |
| | | Therig New Member
Age : 35 Join date : 2012-04-23 Points : 4610 Posts : 13 Location : Akron
| | | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5206 Posts : 392 Location : west chazy ny
| Subject: Re: The Rig mower May 23rd 2012, 12:03 am | |
| dang that trans is dead lol thats y im iffy abt welding my diff seeing i dont have any spares lol and i did the gear oil swap in a tractor of mine only prob i had was it started seaping out the brake part causing brake to slip | |
| | | Therig New Member
| Subject: Re: The Rig mower May 23rd 2012, 8:03 am | |
| - gearheadmike wrote:
- dang that trans is dead lol thats y im iffy abt welding my diff seeing i dont have any spares lol and i did the gear oil swap in a tractor of mine only prob i had was it started seaping out the brake part causing brake to slip
Mine is welded and ive yet to have an issue with it . he welded the gears crooked and thats that caused the slight malfunction | |
| | | gearheadmike Member
| | | | Therig New Member
| | | | Therig New Member
| | | | XJeric Member
Age : 31 Join date : 2012-08-03 Points : 4537 Posts : 39 Location : port hadlock,wa
| Subject: Re: The Rig mower August 3rd 2012, 7:14 pm | |
| Looks like your friend needs a stainless steel axle hoseing or a jr dragster rearend or quad rear end someting more beffy to take abuse . | |
| Subject: Re: The Rig mower August 6th 2012, 5:06 pm | |
| I have a couple tractors with 600 series teccy transmissions ( pretty beefy) - they run berings and gear oil in them- only bad thing is theyre a 3 speed.
From the looks of it - thats the original grease in those busted transmissions - thats exactally what happened to my 85LT12 craftsman with the 18 year old grease in it - best thing to do is crack open those old transmissions, clean that nasty grease out, grease with heavy duty grease and add zerk fittings to sock some fresh grease to it.
I dumped the grease out of my 88 kleen kut's trans - stuff literally looked like baby crap - all thick n nasty and partially filled with water as well. | |
| | | Therig New Member
| Subject: Re: The Rig mower September 19th 2012, 8:58 pm | |
| - dangeroustoys56 wrote:
- I have a couple tractors with 600 series teccy transmissions ( pretty beefy) - they run berings and gear oil in them- only bad thing is theyre a 3 speed.
I dumped the grease out of my 88 kleen kut's trans - stuff literally looked like baby crap - all thick n nasty and partially filled with water as well. Yeah Ya know i was running greas in mine. i posted pics of it when i disassembled ait after some mud water action . filled it up. What i did was i went to walmart they have this cleare general silicone in a huge caulk tube so i used that along with i rings and it sealed right up u went to tractor supply and got some 140w gear oil- filled it about half up on hte bottom used o rings as seals sealed the case and it has never given me a problem. The only thing i would do better if i could would be to make a better drain lug area , the case was to thin so the plug went in but im not sure if i wana take it back out. i dont want to strip threads. but hey it dosent leak at all, | |
| | | Therig New Member
| Subject: Re: The Rig mower September 20th 2012, 11:21 pm | |
| Ya know when people see my lanw mower and ask what do you do with that. When i rpely i get wierd looks and laughs. I tell them dont knock it till you triy it. So if you agree get your friedns on to a mud tractor and let the good time mow | |
| Subject: Re: The Rig mower September 21st 2012, 12:43 pm | |
| I know what you mean! We started out with one tractor like 15 years ago, grown to 5 machines now, and people have always scoffed until they see them in action. Now we usually have about 50 people show up at our yearly event, some participating, others just watching, but everyone having a good time! | |
| | | Trikahilux Member
Age : 42 Join date : 2012-06-29 Points : 4577 Posts : 47 Location : C-Ville Va.
| Subject: Re: The Rig mower October 31st 2012, 12:11 am | |
| - Therig wrote:
I don't see a problem here, the gears look fine. just kidding!!! sweet rigs man, love the doully. deff' would like to see how thats done! | |
| | | | | The Rig mower | |
| Who is online? | In total there are 32 users online :: 0 Registered, 0 Hidden and 32 Guests
