 Homemade 4x4 Utility Vehicle
dylansrockinrigs
dylansrockinrigs
Homemade 4x4 Utility Vehicle Empty
PostSubject: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeFebruary 29th 2012, 7:31 pm
I am going to build an off road utility vehicle using parts from my old truck with a locked up motor. I got the idea here https://www.youtube.com/watch?v=4lDnSH-_Afg and followed a link from there to this site http://www.longwood.edu/staff/riderkb/tractor/index.htm That site proved to be some what helpfull so I downloaded the PDF plans for the tractor this guy built and I have changing, altering, and modifying them for a few weeks one reason being I am not building a tractor and the other mine is going to be four wheel drive I am also going to use an 18 horse power briggs and stratton twin instead of a 9hp briggs and stratton. Here are some videos of my progress and ideas https://www.youtube.com/watch?v=vsJ1s8N1tGs&feature=plcp&context=C3ecba1aUDOEgsToPDskLdvuBYto6HWqk6xwWe3FDc and https://www.youtube.com/watch?v=8WbqlsdKI3E&feature=plcp&context=C39fc152UDOEgsToPDskL0zbr9r0AlMuHJTrYBubBT
Thanks For Looking
Jamus
Jamus
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeFebruary 29th 2012, 7:52 pm
I've looked into building one of those pow'r pups man times, it's an interesting design. 4wd wouldn't be hard, just get a standard transmission from a 4wd with the t-case attached. I have a few Chevy front axles and have thought about shortening them, using short inner shafts on both sides. With a short steering axle you could run 4wd and 4-wheel steer, 4-wheel disc brakes too. At least that's my plan, someday.
http://www.rcbashers.com
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeFebruary 29th 2012, 10:06 pm
Yea ive got 2 old nissan 4x4 trucks I bought them for 1 dollar a piece and Im using one that has a locked up motor to build this thing. Right now Im just going to pull out the differentials, transmission, transfer case, steering system, and drive-shafts then weld up a frame to hold it all together. I like your idea of the four wheel drive four wheel steer but I prefer the four wheel drive front wheel steer
Jamus
Jamus
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 1st 2012, 2:35 pm
Well, your UTV will probably be higher speed than the tractor as well. I was thinking the 4-wheel steer for a slower tractor, maybe even hydraulic steering, independent front/rear. I'm looking forward to see what you come up with. I have a free subaru coming my way that I'm going to build into a woods vehicle of some kind.
McHandyMan
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 1st 2012, 9:05 pm
This is a iffy idea, make a frame and make a mount to put the trans axel in the middle. Make sure it locked! Now build motor mounts and make sure the pullies line up. Where each of the wheels go on the trans axel make somthing to run drive shafts off them, thus the need to lock them. Now just get the axels figured out and make mounts for the body you will be all set. I have been thinking about doing it myself but I don't got the time. Or space. There's people out there with awesome ideas but no way to put them out there and I think I just had one haha, hope you can understand. Only grade 9 English.
dylansrockinrigs
dylansrockinrigs
PostSubject: @McHandyMan   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 1st 2012, 10:12 pm
I don't quit see what you are thinking or trying to get at but I am not going to lock the diffs because I need to have as tight of a turning radius as possible for the applications I am going to put it to. plus the trails I will be riding on are going to be narrow and tight on some corners plus my transmission/ drive-train setup is coming out of a 84' Nissan King Cab 4x4 it is the brownish orange colored one in the video below. These trucks are great off road and I am going to gear it low so I shouldn't have any problems.
And whatever "only grade nine english" means could you please explain?
https://www.youtube.com/watch?v=u069sLqjCQU&feature=plcp&context=C3c25888UDOEgsToPDskLNuzh-W_8R8ag3Utg1jUCT
Jamus
Jamus
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 1st 2012, 10:24 pm
Under his name it shows his age, 15, therefore he's in the 9th grade.
I think he's describing using a vertical shaft motor with a lawn tractor transaxle as a transfer case. It's been discussed before, but dylansrockinrigs already has truck parts to use, which will be stronger and cheaper.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 1st 2012, 10:44 pm
I don't think a lawnmower tranny could handle what I am doing without making funny noises while towing and still being able to travel at high speeds and have four wheel drive. Only grade Seven english and in Algebra 1
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeMarch 5th 2012, 9:56 pm
I changed my plan so I don't have to get a welder or some angle Iron.
I'm just going to pull the locked up motor out of my truck pull the rusty bed off and mabey pull off the cab but I'm thinking about keeping It on so I can hook up a heater in the winter then I'm going to hook up the clutch brakes 18 horse briggs twin pulleys and I'm thinking about sticking a little alternator In the to take some drain off the battery
dagr8tim
dagr8tim
PostSubject: Re: Homemade 4x4 Utility Vehicle   Homemade 4x4 Utility Vehicle Icon_minitimeJune 2nd 2012, 4:42 pm
Google "Truggy".
http://buckeyejeeps.com
» my current vehicle projects
» Homemade Mortar Mixer / Utility Trailer Conversion
» Tracked Lawn mower
» E.R.V. Earth Rover Vehicle really just a 2017 pioneer 500 - PLOW MODS
» What do you guys keep in your vehicle?
