| International Cub Cadet 1650 | |
+5Crazy_Carl Customrust biggasmowers AllisKidD21 muckmudd 9 posters |
| Subject: Re: International Cub Cadet 1650 April 21st 2018, 9:46 pm | |
| If the dipstick show oil in the cross-hatching, then she should be good to go. Also make sure when you go to try and start it you have a battery with a good charge, or it might not make very good spark and possibly won't fire. | |
Age : 22 Join date : 2016-10-29 Points : 7203 Posts : 4011 Location : Lewisburg, KY
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3552 Posts : 825 Location : In the shop
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 12:40 am | |
| I don't really care if it doesn't fire at the moment, I just want to see it turn over to prove that the engine is OK and the electrical is too. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 1:09 am | |
| Found this online, It seems to be exactly what I was looking for to help me understand my tractor a bit better. I'ts those small things like the speed control stop that get you confused. So the little knobs are the fuses still confused about them. They don't look like your average fuses? | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5324 Posts : 2561 Location : Rochester, New York
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 9:37 am | |
| those fuses are actually pretty common. those fuse holders hold those little glass fuses that are usually quarter inch by 1 inch long. I’m probably wrong about the length. that’s awesome that the fuses are right on the dash. I can see why these cub cadet tractors have a cult following just like wheel horses. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 10:54 am | |
| So, do they unscrew out the dash or something? If those are blown I wouldn't be able to start it?
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 11:32 am | |
| I'm pretty sure this Kohler has a 12V ignition coil so if your battery fuse is blown you're not going to have any spark. I'm pretty sure all you have to do to check those fuses is push the cap in, turn it counterclockwise a quarter turn to release the cap or the cap may just thread on and you can unscrew it and the cap should come off to reveal the fuse. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 8:01 pm | |
| https://www.youtube.com/watch?v=Auk6SvKPNe0Here's a link for you guys. Finally got it to crank. It takes a lot of battery power to crank that monster though. If it cranks does that mean the fuses are fine? Because I sprayed ether in the carb and it still wouldn't fire. The spark plug looks fine, what else could make it not spark. I need to go find my spark tester however and see if it works. | |
Age : 20 Join date : 2017-06-09 Points : 5483 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 8:14 pm | |
| The coil could keep it from firing, if it is chewed through or maybe the part that contacts the flywheel is bad, or it is not contacting the flywheel right. Oh and new subscriber BTW. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 9:11 pm | |
| Get a charger on that battery. Check for 12V on the coil on the terminal that the ignition wire is hooked to. There's three wires that go to the coil1)ignition wire from the dash somewhere 2)spark plug wire 3)wire going to the points | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 9:36 pm | |
| IDK you'd have to charge the battery, then you have to check the specific gravity of the acid in the cells or use a load tester on it to know for sure. I'd just spend the $40 or $50 and get a new one. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 9:40 pm | |
| Yeah I'm planning on getting 1 new battery. I have 4 tractors and one good battery would really help to go along with the two that are sorta lazy. I'm not good at all with electrical. So pretty much I check the coil with a mulitimeter to see if it's putting out 12V?
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 9:43 pm | |
- The coil could keep it from firing, if it is chewed through or maybe the part that contacts the flywheel is bad, or it is not contacting the flywheel right. Oh and new subscriber BTW.
What kind of coil is it? Like a magneto? Or is it like some sort of strange points system? | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 10:03 pm | |
| - muckmudd wrote:
What kind of coil is it? Like a magneto? Or is it like some sort of strange points system? I have no clue, I've never messed with that kind of engine. That's just a symptom of that. Sorry man. | |
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 10:09 pm | |
| It has points on the side of the block that ground out the coil when it doesn't need spark. They're under a little sheet metal cover, near the fuel pump and carburetor. | |
Age : 25 Join date : 2016-07-10 Points : 8578 Posts : 5190 Location : Ontario Canada
| Subject: Re: International Cub Cadet 1650 April 22nd 2018, 11:34 pm | |
| I'd clean and re-gap those breaker points. They should be set to 0.018"- 0.020" if I remember correctly. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: International Cub Cadet 1650 April 23rd 2018, 12:01 am | |
| Ok then. I'm not too familiar with points, In fact, iv'e never worked on them. I will see if I can find them tomorrow. I was also afraid that I was afraid that I would have to remove the entire engine to work on them because I thought that they might be on the shaft side. I am also thinking of removing the front heat shield. Its kinda just in the way and more than half of the bolts are stripped out of the aluminium or broken off. I don't really see why I need it but I will definitely keep in just in case. BTW, do heat shields need to be painted with engine enamel stuff or will regular black spray hold up? | |
| Subject: Re: International Cub Cadet 1650 April 23rd 2018, 7:07 am | |
| I'd use engine part or look on the can of spray paint you have and what temperature it's rated for. These tins on air cooled engines get pretty warm but not super hot either. | |
| Subject: Re: International Cub Cadet 1650 June 6th 2018, 11:42 pm | |
| Well not much happening with this ol' hunk of metal. Sanded down the points and she has spark now. Still doesn't run. I jumped it off my truck's battery. The ACR seems stuck shut because the compression seems very high. I really don't know what's going on with this thing and ANY help would be appreciated. https://www.youtube.com/watch?v=4G_MSD5j-9sThis is a short clip to show what's happening. And I think it is just vaporized gas not exhaust that's coming out the carb. | |
Age : 49 Join date : 2016-09-06 Points : 15648 Posts : 10973 Location : Oklahoma
| Subject: Re: International Cub Cadet 1650 June 7th 2018, 12:37 am | |
| Points timing off? After sanding the points the gap may be a few thousands larger. There should be a screw that you can narrow that gap a little. There should be a procedure for the engine to adjust that to so many thousands...
Maybe even check flywheel key if that is all good. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5744 Posts : 1993 Location : Northern Ireland
