| transaxle stuck in third gear | |
davidgt6000 Member
| Subject: Re: transaxle stuck in third gear January 28th 2013, 7:35 pm | |
| - dangeroustoys56 wrote:
- Chassis looks just like my weedeater tractor - till MTD took over making newer craftsmans , most the old older LT's are nearly all the same chassis/transmissions - even have a poulan thats the same as the weedeater.
Id still crack it open anyway , that was my thinking back then - it didnt work, so even if i broke or screwed it up, what did it matter? I still have a couple spare transmissions around anyway. yeah im going to open it up, got it ready to drop now. | |
CornishMorgan Member
| Subject: Re: transaxle stuck in third gear January 28th 2013, 10:29 pm | |
| Yeah that's going to be your best option i think.
Just remember to open it slowly and carefully and find and keep safe the little ball and its spring for the shifter. | |
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4460 Posts : 121 Location : PA
| Subject: Re: transaxle stuck in third gear January 29th 2013, 10:44 am | |
| about the same that happened to mine. someone told me that a bolt(?) is bent and preventing it to move | |
davidgt6000 Member
| Subject: Re: transaxle stuck in third gear January 31st 2013, 2:13 pm | |
| that looks nasty, no wonder it wasn't shifting properly. Give in a clean with some petrol, a paint brush and lots of old rags and it should be as good as new, providing nothing is broken. | |
davidgt6000 Member
| Subject: Re: transaxle stuck in third gear February 1st 2013, 10:30 am | |
| i took the rearend out of this craftsman ll and put it in. had to change mounting brackets though, but its mobile now. | |
Age : 54 Join date : 2010-02-10 Points : 7079 Posts : 1726 Location : Florida, USA
| Subject: Re: transaxle stuck in third gear February 2nd 2013, 6:12 am | |
| Thats what i saw in a MTD transaxle i took apart the other day - all nasty looking grease - my plan was to swap some internal parts with another ( for the brakes) - oddly they wernt the same- one had bigger pieces inside then the other .
The one i wanted to fix had better tires the the donor ( its a b*tch to pull MTD rims off) was hoping to swap the brake setup over - but they were nothing alike - i need to go thru and check my other spare MTD transaxles anyway - ive been thinking of redoing a couple good ones for spares ( and putting zerks in ) and taking the rest apart for spare pieces. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7785 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: transaxle stuck in third gear February 2nd 2013, 4:18 pm | |
| - davidgt6000 wrote:
- i took the rearend out of this craftsman ll and put it in. had to change mounting brackets though, but its mobile now.
Looks like the Craftsman I donated to my friend. We swapped a 18.5 Briggs Intek V into it though. Nice machine, we pulley swapped to a 5" rear I believe. had to redo the linkages for the shifter though so it only goes into 3rd so we gotta redo it, but she flies in 3rd. We were popping wheelies with it with the massive 18.5 in it too. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
davidgt6000 Member
Doug Site Owner
| Subject: Re: transaxle stuck in third gear February 2nd 2013, 4:36 pm | |
- this one has 14 opposed twin in it, needs some card work.
Guess they were a bit different then, mine had a 14hp Briggs Vanguard V in it before we swapped it. Now that I look at the pic more I see the gas filler cap is on the outside. Mine was under the seat. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: transaxle stuck in third gear February 2nd 2013, 5:06 pm | |
| My fuel tank is mounted to the bonnet with the cap on the outside. I'm not that keen on it being there, Ill move it at some point.
Last edited by CornishMorgan on February 2nd 2013, 5:28 pm; edited 1 time in total | |
davidgt6000 Member
Doug Site Owner
| Subject: Re: transaxle stuck in third gear February 4th 2013, 2:41 pm | |
| CornishMorgan: "My fuel tank is mounted to the bonnet with the cap on the outside. "
Yeah my '82 dynamark has the same setup - can only open the hood with the tank around 1/2 full or itll leak all over - you can make a bracket to bolt it to the chassis instead. | |
davidgt6000 Member
| Subject: Re: transaxle stuck in third gear February 7th 2013, 3:33 pm | |
- CornishMorgan: "My fuel tank is mounted to the bonnet with the cap on the outside. "
Yeah my '82 dynamark has the same setup - can only open the hood with the tank around 1/2 full or itll leak all over - you can make a bracket to bolt it to the chassis instead. hahaha yeah if its more than half full petrol comes out the cap, its a pain, Ill fix that someday. Not helpful over big bumps while smoking | |
