| | How to upgrade steering gears and tie rod? | |
tractorboy567 Member
![tractorboy567](https://2img.net/u/2812/37/66/46/avatars/562-12.jpg)
Age : 26 Join date : 2013-01-02 Points : 4382 Posts : 121 Location : PA
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | Subject: How to upgrade steering gears and tie rod? January 21st 2013, 7:07 pm | |
| i let someone drive my tractor a couple days ago and i didnt tell the that my steering gears were bad, so , naturally, they hit a building with one tire and bent my tie rod. my wheels were like \ / and the gears stripped even more when they tried to keep on driving. my tie rod is unbent now but my question is if there is any way to fix or upgrade my tie rod and steering gears without buying stock parts and will last a long time and take a beating and FOR CHEAP!!!!! it has broken to many times now. | |
| ![Go down](https://2img.net/i/empty.gif) | | Chopperhed Moderator
![Chopperhed](https://2img.net/u/2812/37/66/46/avatars/469-45.jpg)
Age : 58 Join date : 2012-10-14 Points : 5179 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7704 Posts : 3044 Location : Lebanon County, PA
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to upgrade steering gears and tie rod? January 21st 2013, 9:26 pm | |
| You could do a direct steering setup. Look around the forum for a tutorial on how to make one. Its fairly simple and doesnt use gears. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| ![Go down](https://2img.net/i/empty.gif) | | Tractor Man Jeff Moderator
![Tractor Man Jeff](https://2img.net/u/2812/37/66/46/avatars/375-11.jpg)
Age : 29 Join date : 2012-06-26 Points : 4938 Posts : 492 Location : Back in the sticks of VA
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to upgrade steering gears and tie rod? January 21st 2013, 10:20 pm | |
| As for the tie rod, you can do what I did. I used a 1/2" rod and welded it to the tie rod. I've since then dropped a golf cart axle and steering into my tractor. ![How to upgrade steering gears and tie rod? DSC_0385_zps1bf907f2](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/DSC_0385_zps1bf907f2.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | dangeroustoys56 Veteran Member
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7001 Posts : 1726 Location : Florida, USA
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to upgrade steering gears and tie rod? January 26th 2013, 2:42 pm | |
| These are setups on direct steering found at Hey mow - the pic is of a racing tractor at the site: ![How to upgrade steering gears and tie rod? Direct11](https://i.servimg.com/u/f16/14/87/67/58/direct11.jpg) ![How to upgrade steering gears and tie rod? Direct12](https://i.servimg.com/u/f16/14/87/67/58/direct12.jpg) If its a craftsman, i did a swap on my 99 weedeater that had crappy plastic pieces in the steering - i took the steering setup out of my parts 85LT12 and did a virtual bolt in swap with minimal modifications - works tons better then original. | |
![How to upgrade steering gears and tie rod? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | How to upgrade steering gears and tie rod? | |
| Who is online? | In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests
