| TMJ's Craftsman LT1000 Conversion Thread | |
+43camomanusa Andy from Chenango Forks 1997 Murray Krawler86 FOSWMT Doc Sprocket Murray modder MurrayMayhem megamudder redlinemotorsportts richie thomas xxXMowerdudeXxx Thunderdivine killerbob11122 crafsmankiller THE MTD GUY Doug BlackMountian88 dagr8tim truckin42 dked41 Chopperhed Josh Blair W1ldyOvvnZ Craftsman Dude greener179 TennesseeCowboy F150F250F350 TheRainbowBoxer WellThatsSurprising craftsman30mph XJeric muddstir Wheel Crazy MSteele323 matthew sidor Trikahilux Hillbilly Homer dangeroustoys56 dylansrockinrigs tractormods CornishMorgan Tractor Man Jeff 47 posters |
Tractor Man Jeff Moderator
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 21st 2012, 10:30 pm | |
| OK, that's not it than. I could unplug it and it would start to shut off, then I would plug it back in and the engine would kick back on. What else would cause this? | |
Age : 29 Join date : 2012-06-26 Points : 4968 Posts : 492 Location : Back in the sticks of VA
Wheel Crazy New Member
Age : 53 Join date : 2010-02-10 Points : 7031 Posts : 1726 Location : Florida, USA
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 26th 2012, 6:57 am | |
| Looks cool - not being sky high, it should be more stable . Ive had a few OHV motors that the antifire solenoid screwed up in - snipped the end off and havent had trouble since .
Does it have an exhaust on it? Most times why it 'pops' is because of unburnt fuel - on my tractors I usually shut the gas valve off, then just let them idle till they stop on their own , it emptys out the carb of gas as well . | |
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 26th 2012, 10:59 am | |
| Thanks guys. Yeah, It now runs good. I'm working on the exhaust now. Still trying to figure out how I'm going to do it. I've even gone trail riding in it. The front end needs some work. Still lots to do. | |
matthew sidor Member
Age : 30 Join date : 2012-04-13 Points : 4746 Posts : 184 Location : Montesano, Washington
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 26th 2012, 11:01 pm | |
| The first one i think looks the best unless u can make the second one look better the third one is to tall and could hit trees. the second one looks to ghetto so im still saying the first one | |
muddstir Member
Join date : 2012-01-22 Points : 4992 Posts : 318 Location : Western,PA
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 27th 2012, 10:49 am | |
| The second one (third pic), I think would look better once its all welded up and ground smooth. I'd add a little more pipe coming out of the bend and increase the angle of the cut, maybe even put a little curve to it too. The frist setup dont look to bad either.
One ? is your hood going to be able to open with that setup? Anyways your tractor is looking good. | |
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread July 27th 2012, 10:52 am | |
| All I have to do is unscrew the fittings to open the hood. I'll get some different fittings so it will be easier to open the hood. I'll make a new turn-out tip that has a better bend in it. | |
XJeric Member
Age : 31 Join date : 2012-08-03 Points : 4492 Posts : 39 Location : port hadlock,wa
XJeric Member
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 4th 2012, 6:53 am | |
| kinda has a trophy truck look to it now with the fenders with some custom paint and lots of stickers and a link type front end and fox shocks tether kill switch and built to the hilt motor and side pipes would have a bad ass race look > | |
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 4th 2012, 3:56 pm | |
| There is still plenty of "Lawn Mower" left. It just looks like a lawn mower with big fenders. Them big wheels will throw some mud I'm sure. I personally like them. A coat of paint will help though. What color should I paint him? I was going to do camouflage. | |
XJeric Member
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 7th 2012, 2:52 pm | |
| Got the gas pedal hooked up. It works great. Wasn't sure how I would do it. I'll get pics soon. Next step is to see if I can somehow flip the engine pulley around and use the bigger size. Any ideas? | |
Hillbilly Homer Member
Join date : 2012-04-22 Points : 4795 Posts : 197 Location :
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 7th 2012, 5:37 pm | |
| This is how i did mine. Black = The washer on the inside . Red = cut. Green = Drill hole and welled a nut over hole use a bolt as a key[img] [/img] | |
craftsman30mph Member
Age : 32 Join date : 2011-08-23 Points : 4984 Posts : 127 Location : branch MI
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 4962 Posts : 407 Location : East Bethel, MN
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 10th 2012, 11:46 am | |
| If someone can tell me how the Honda 250 High Performance ATV brakes work, sure, I'll do it. Y'all see, the ATV the brakes came from only had the calipers, disks, and some of the tubing. I'm missing the main part that makes the brakes work. I don't know what the part is. That's the problem. I do need brakes though. I'm still trying to figure that out. Thanks Homer for the suggestion. That's what I think I'll do. | |
| Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 10th 2012, 1:01 pm | |
| take a picture of what brake parts you got and ill tell you what else u need. and for the pulley i cut the end off so their was a little bit of the key still on it .and flipped the bottom end to the top. so the bottom end is on top then I got on the lathe and drilled it out to right size without going all the way to the key so it will still be able slip right in to keyway. then i re-welded it so the small one is on top and big one is on bottom | |
